Stealth back up light bar DIY project
Eyesore
Scott
Snohomish Wa
2024 FDM, 1990 Ford Ranger, 2005 Tacoma, 2007 Rav4
Systems Engineer
I needed some back up lights that would show over the top of my receiver hitch plow. I also wanted to maintain the stock look and wiring.
I started with this ACI 39" BACK-UP LED LIGHT
https://shop.agricover.com/product/backupledlight
this is the light strip just above the license plate in the below picture.
Tesla Roadster 2nd gen Stealth back up light bar DIY project IMG_2816
To route the wire from the backup light strip to the trailer hitch connections,, I took off the bumper facia and went over some trim and then down past the casting.
Tesla Roadster 2nd gen Stealth back up light bar DIY project IMG_2812
By the way, this is what the energy absorption of the bumper looks like.
Tesla Roadster 2nd gen Stealth back up light bar DIY project IMG_2814
To maintain the stock wiring, I used a 4-Way Trailer Wiring Harness with 5 ft Wires 4-Pin Trailer Wiring Jacketed Cable 4 Flat Trailer Wire Extension Connector
https://www.amazon.com/dp/B08BNBZR4T?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
I just tapped into the reverse wire and ground wire of the pigtail. Didn’t use the four-way trailer wire extension.
Here is a pinout diagram for the seven way connector:
https://www.ajtnt.com/Info/7-Way-Diagram
Tesla Roadster 2nd gen Stealth back up light bar DIY project IMG_2819
and this is using the test trailer light function to light up the light bar.
Tesla Roadster 2nd gen Stealth back up light bar DIY project IMG_2820
I was worried that tapping into the trailer connector would cause a trailer to be detected and bugger the FSD, but it doesn’t seem to know.
devdrone6
Dev
Nebraska
Cybertruck, 2023 Model Y
Good job, I'd like do something similar as well. For me the reverse camera is too week in the dark, maybe my aging eyes.
tmeyer3
Trevor
www.meyerwine.com
Computer Scientist, Vintner
This is a good walk through, thanks! It doesn't take much, any amount of extra light even reversing is a great upgrade.
I was thinking of doing something like this also. I personally would want it on its own switch instead, but great idea.
It's not just you, the reverse camera + lights at night are pretty weak.
ChiTownCT
CT
Chicago
CYBERTRUCK
Looks great OP, I always thought another brake light would be helpful too. Current setup I feel drivers dont understand I'm braking.
CyberZephyr
Long Island, New York
2021 MY, 2023 MX
Looks great! Can you post a video?
scottf200
Western NC
X; immed family 3 & Y
The towing that I've done in two Teslas are sensitive to the weight of what you are towing before they affect AutoPilot. Light trailer was fine if you used modest speed and braking. Heavier 12x6 U-haul kicked it off right away.
BlueLightning
Thomas
Oklahoma
Retired USA, Army
lol, guess they found a use for that millions Of Dollars mega cast machine from France that they stopped using.
CyberZephyr
2021 MY, 2023 MX
Lasttoy
Paul
St Augustine, FL
Weird. I plugged in a LED light bar for lights. Wouldn't work.
Put on RV. Worked
Put on my PU. Worked
Tried on another truck , Worked
Still Would not work on CT???
LuvOrH8
San Diego, CA
Cyber Truck
Put on RV. Worked
You probably connected it to a 48v power feed and not a 12v is my guess.
Eyesore
Eyesore
Scott
Snohomish Wa
Systems Engineer
One strange thing I recently noticed. When the car is on, the backup light strip blinks with very low power, barely discernible in the daylight. I'm interested in theories as to why it would do that. This is wired in to the trailer backup light circuit. Once the car goes to sleep, the blinking stops.
