Dead truck.
65SoYoLO
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
Retired truck driver
Going to try that in the morning before heading to the service center with My girlfriend's old faithful Ridgeline.
swampcrawler
charlie
miami
3, S, CT
Once you jump it on the posts in the frunk, you can open the tailgate, to get to the chargeport release.
But jumping the 48V doesn’t get it ā€œreally goingā€, it just limps along enough so you can get it to tow mode and to the SC, so opening their chargeport shouldn’t be your priority.
JCERRN
Around
Yeah
Please keep us updated on what happened. Most recently the major failure is the link between the HV and MV system, the PCS. Not sure why they're failing but several have. Mine did.
65SoYoLO
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
Not on that much of a rush...
Tesla Roadster 2nd gen Dead truck. 1000017036
PungoteagueDave
Boynton Beach
ā€˜25 Tesla Cybertruck, ā€˜26 Tesla MY Launch, ā€˜13 Porsche C4S, ā€˜26 BMW R1300 GSA
How do you jump start a 48 volt battery? All my jump packs and chargers are 12 volt
Edit - never mind. https://service.tesla.com/docs/Publ...UID-BC28BE8A-5596-498C-8D4A-A6BB75096A81.html
swampcrawler
charlie
miami
3, S, CT
That's why it doesn't really run everything, it just limps along so you can load on the flatbed.
First you have to pull the little pigtails out of the front of the driver side front fender. That will give you enough power to open the frunk. In the frunk are two posts in front of the driver under the plastic cover, that you connect to, to power the mainscreen, which allows you to put it in tow mode.
Mine was plugged in when it died, so we had to open the tailgate to get to the charger release cable.
The tow truck driver seemed to know the drill.
Kenneth K.
K-ster
CA.
TeslaCybertruck, Tesla Y, Tesla 3, and Zero SR.
Health care professional.
When nothing worked, schedule service with TSC. Please keep us posted, hope everything works out.
Hohenzollern
Matthew
2025 CyberTruck AWD - 2004 Infiniti G series (Original Owner)
Is there a 48v power supply on the market with a longer (as opposed to a 12v burst) suitable for powering up the truck?
BeFamousVideo
Vincent
Orange County, CA
CT Beast delivered May 2024
Automation Agency
Loaded some addresses into the truck and headed out of the driveway to view Christmas light displays at locations posted online. I made it about 100ft down the road and had to stop to clear the headlights. Got back into the truck and started getting all the lights and warnings. I barely made it back to the house by backing down the street right into my driveway. Tried a few things, screen reboot, hard reboot, nothing. Now, I am locked INSIDE the truck. and nothing is working. No power at all, no screen, no window power, I had to use the emergency release...and I was REAL careful when I closed the door.
Here are some videos with the issues.
Many forum members would be interested in what Tesla does for you in this situation and what the cause was for malfunction.
Please post follow up.
A problem this severe should rise to the top at Tesla engineering.
65SoYoLO
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
I was able to borrow a 48 volt battery charger that fired the truck up and it is now updating the software with 44.25.5 The tech told me that they had a problem with one of the software versions that would cause this issue. I hope this works.
65SoYoLO
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
I was able to borrow a 48 volt charger that runs off for 120 that's what's powering the truck right now during the update.
daveog
Winter Garden, FL
2026 Model Y, 2025 Cybertruck AWD
Wow, that's crazy! Thanks for keeping everyone up to date. For my knowledge, and probably others, what is the process for "jump starting" a CT with a 48V power supply? And where does one get one of those?
65SoYoLO
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
I can't tell you where I got mine but once you get the front open using the terminals by the light right about in the middle of the front next to the brake booster you'll see the positive and negative terminals there connected and plug it in. The one I borrowed is 120 volts so you need a outlet to plug it in.
65SoYoLO
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
The truck downloaded the update but it's not installing it. It just says preparing to update but never does.
Tesla Roadster 2nd gen Dead truck. Screenshot_20251215-124809
