h1cksta
- Oct 17, 2023
- California
- Cyberbeast, Ram 2500 Cummins 4x4
Yesterday morning, I went out to my truck after it had been sitting since Christmas Eve, roughly one week. I'd gotten a message that the right rear was low (it appears a nail had caused a slow leak). I refilled the tire, and then jumped in the truck. Battery showed roughly 50%.
When I went to put it into drive, I got a plethora of error messages (See attached screenshot).
Active codes showed as:
RSA_a211 Rear steering axle disabled - Turning radius limited. Exiting and re-entering vehicle may restore feature.
PEPS_a182 Rear axle steering disabled - Turning radius limited. Exiting and re-entering vehicle may restore feature.
DI_a062 Power reduced. Exiting and re-entering vehicle may restore feature.
VCRIGHT_a220 Low voltage electrical system issue detected. Vehicle power reduced. Schedule service.
HVBATT_a046 High voltage system error detected. Vehicle may not restart. Service is required.
Additionally, in the log were the following codes:
EGGRIGHT3_a447 Cabin climate control system requires service. Cabin heating/cooling limited or unavailable.
VCSEC_a221 Air pressure below recommendation for tires. Check pressure or refill tire as needed.
VCRIGHT_a361 Windshield washer fluid low.
I tried resetting the computer, and then did a hard reset with both steering wheel buttons. No luck.
The truck would not drive, so I scheduled a service appointment through the app - 14 days out! Not very impressed by that, on a vehicle that was inoperable. Fortunately, I still had my old Ram, so I took that to work.
By the time I got home, I'd got a notification that the truck had the 2025.45.7 update available. Figuring I had nothing to lose, I plugged in the truck, and installed the update overnight.
Fast forward to this morning, I went out to the truck hoping I could limp it out of its current spot to make access to the garage easier. Magically, all the active codes had cleared. Car was drivable, put 60 miles on it today with multiple stops, no problems.
Does anyone have any ideas what could have caused this? The truck is a Foundation Series, serial number roughly 19000 if that helps. I presume I should keep the scheduled appointment.
Thank you for the help!
