Charge on Solar now enabled for Cybertruck
AlmostHuman
Earth
Model X, Cybertruck
Human
What version are you running? I do not see that.
gaubong053
Tuan
Sacramento, CA
MXP, Cybertruck AWD FS.
Software engineer
4.33.0-2668. It suddenly enabled this morning, so I think Tesla push it to customer just like Powersharing feature.
rrolsbe
Ron
Reno, NV
2023 Model 3 RWD
Looks like Tesla finally enables charging on solar for Cybertruck.
Check to see if the AC power outlets in the bed can be activated/supply power while charging from solar or any AC source. I believe a previous firmware enabled the AC truck outlets to be used while DC Supercharging. It would be nice to use the truck battery as a power source/buffer while AC slow charging.
TwilightHan
Han
Austin
2022 Model S, CT Beast Now Ordered
If you had Tesla energy and the $25 plan for unlimited charging, would it be better to sell the solar during the day and just charge at night for free? The plan comes to be around $0.83 a night for charging.
Tringa2
HJ
Saint Paul, Minnesota USA
Model 3 LR
For my ideal use case, the Cybertruck would allow a *direct* (DC only) connection from arbitrarily configured solar array(s). The solar panels wouldn't need to have either microinverters or optimizers attached. I've seen no evidence anywhere that the Cybertruck has an on-board MPPT controller, but I would find it very useful if it were possible to directly connect solar panels to the vehicle, even if it would only result in a "trickle" charge.
Gene
Gene
Santa Barbara, CA
Tesla Model Y.
Investor
I noticed the Charge on Solar after a phone app update so check your app that it’s latest
flyinglow
Rick
Sierra foothills, CA
BMW 335i, F250
Depends on state/utility. If you have TOU (time of use) rates you are correct. It makes more sense financially to sell power to the utility at high rates and recharge at lower rates. However, TOU peak rates don't generally start until mid to late afternoon, so you can solar charge up until then.
AlmostHuman
Earth
Model X, Cybertruck
Human
Interesting. My app is on 4.33.5-2673 with the Cybertruck on 2024.14.11 and Powerwalls on 23.28.2
Looking forward to the Charge on Solar option
Obie_fl
Tom
2018 Model S, 2024 Model Y, Cybertruck FS AWD
I had this same thought the other day. A DC direct connection should be so much simpler and efficient. Maybe a third party solution from someone?
jf64k
I’ve got it, too. v4.33.5-2673
AACS
CyberTruck
How about connecting an external solar panel array with an MPPT controller?
Can the DC output from the MPPT be connected to a DC port, like adding another MPPT to the vehicle's power bar? Is there such a port?
AlmostHuman
Earth
Model X, Cybertruck
Human
Nope, the only port to charge is the NACS port so you’d have to connect the MPPT to charge of some kind, like the mobile charger.
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
Retired truck driver
Do you still have this on he app?
