BornToFly
- Richard
- Nov 27, 2019
- Utah
- S, X, 3, Y and CT
I spent an entire day building this. Attached to the truck using the 8 crossbar mounting points. I can remove the eight screws and remove the entire structure with my wife on the other side. Or I can remove 4 more screws and remove the front section separately from the rear section. Will start covering it with corrugated plastic sheets tonight.
Hopefully can get a range test with an Airstream Basecamp or Bambi later in the week if I can find a rental in SLC. Will test the same out and back with and without the wind deflector. I don't know if the drag behind the deflector will be worse than the drag from just the trailer. We will see....
