GhostAndSkater
It's a 500+ kg hunk of metal, to increase it's temp ignoring any losses by 20 °C (or °F) takes 2.8 kWhThat's quite a bit of heating power. I'm surprised it takes up to an hour to heat the pack. It is very massive, of course.
Would it make sense to insulate the underside in cold climates?
I don't think insulation would help much, there is already an air gap between the bottom of the pack and the cells, which is a pretty good insulator, but it's only a few mm thick, so there isn't much you can put there that would help when you have 40+°C temperature delta
And all is all, 2.8 kWh isn't much, it's a matter of educating people on how to use the vehicle in those conditions
