15k miles on my Beast's stock Goodyears with 6/32" tread left............I was gonna try and milk another 5k out of them, but I got a three inch piece of steel in a rear tire. Discount tires said they were unable to fix the slice... so I bit the bullet and ordered the Michelin platinum tires. They told me I should expect 70k to 80k from them... I know they are sales people so in my mind I am hoping for half of that. So far every tire rotation they have done for free nd have actually fixed a tire previously that got a nail in it for free. I try to be loyal to good customer service.
I am curious though, how many miles did you folks get on your original tires? The salesman told me mine were pretty much used up, but I am a poor Missouri boy and I actually thought the tread was not so bad. I remember when I first got my Foundation Series there were members of this forum that were having to replace them closer to 10k... so I really tried to be as gentle as I could be with them.
Appreciate your input.
As reference from Grok..........15k miles on my Beast's stock Goodyears with 6/32" tread left............
This is the exact reason why i said "Not exactly sure how tire warranty works" there are too many caveats to their warranty language that most cannot decipher.Tire warranties are typically on a prorated basis. IE if you get 40k out of 80k, you get half... and you have to get to (or below) 2/32 before the treadwear warranty applies. There is a bunch nuance to it though... proven rotations (usually with receipts), tire pressures, alignment, seasonality (if tires aren't rated to cold temps), etc etc. Time is also a big component too. There are manufacturers that put 100k warranties on them, but it only applies for 4 years (most are 5 or 6). Some even put it as manufacturing date and not date of sale. So it might be 5 years from manufacturing date and the tires might be 6 months old prior to them being sold. Basically designed for it to be enough of a headache that people just move on.
Even those have gotchas... If you wear down the tires say 6/32 and have one that either through a hazard or just has bad wear. They only pay for the one tire, and they will not pay for the other 3 that will then need to be replaced because not doing so would cause premature differential wear.This is the exact reason why i said "Not exactly sure how tire warranty works" there are too many caveats to their warranty language that most cannot decipher.
I always buy from a reputable tire company. Tirerack or discount tire and buy the warranty. Usually its no questions asked and they send you a replacement.
Speaking of, sometimes I get a rubber smell (like there's been some wear on the tires) when I get home and park in my garage. This is after normal driving (nothing aggressive). I've always wondered if that's due to the 4 wheel steering (and I've had Tesla do a 4 wheel alignment a few months ago)...I'd agree, since it's all down to friction and heat. The average driver probably isn't conscious of how bad it is to dry scrape your tires on pavement.
I have allowed quite a lot of people to test drive my truck, and I always try to explain to them how powerful and quick the steering is, and to please try to have a smooth roll forward before turning the wheel sharply.
What have more than 80% of them done immediately after what I just explained? (Groaning metal suspension and sandpaper grinding tire noises)
Yep. They are already at full lock, and we haven't moved.![]()
Ummm... those should have definitely been rotated and 4mm is on the verge of needing replaced.24,800 on OEM AT (FS AWD) so far.
Took it in for cantrail recall and asked them to rotate the tires.
Telsa measured 6mm in front, 4mm in rear and said no rotation was needed.
On the highway, or any driving above around 40 mph, a vehicle with 4-wheel steering and proper alignment will experience slightly less tire wear than an equivalent vehicle without 4 wheel steering. That's because the front and back steering slip angles work in harmony with one another, reducing tire scrubbing at speed.remember we love the 4 wheel steering, but it eats tires
those warranties of 50K+ miles are for two wheel steering vehicles
no matter the brand or model tire, id say 30K is the best you'll do
vs giving up 4 wheel streering....no way
I would take it back and have them rotated unless you are ready to buy new tires for it shortly. I'm guessing the Service Manager was just trying to reduce the workload on his crew.24,800 on OEM AT (FS AWD) so far.
This written correctly? AWD has rear wheel tire wear bias, as stated by Tesla mobile service, probably should have rotated….24,800 on OEM AT (FS AWD) so far.
