firsttruck
Some times it depends on the definition of "work"But the real question is does your car still work after all the repairs you made?? Lol![]()
Had that problem long time ago. Sucks.My favorite problem on a modern ICE vehicle is sensors. The sensors that are suppose to tell you that there is a problem actually end up being the problem and not what they are trying to sense....
is this limited to ICE?My favorite problem on a modern ICE vehicle is sensors. The sensors that are suppose to tell you that there is a problem actually end up being the problem and not what they are trying to sense....
My F350 had an failed oil pressure sensor. Until it was replaced it would not start. ICE vehicles have more sensors because the ICE engine has more parts.is this limited to ICE?
because the Lightning has, for example, a front air dampener with a sensor that goes glitch for a lot of people a lot of the time, with no apparent fix yet
doesnt change or effect the operation of the truck, it's just an annoying alert for no reason except the sensor having some issue
Sure does, had a 2016 Ram 1500 and was cruising about 75 on the highway and the engine just shut off? Wasn’t the fob battery, fuel issue, or electrical. It was a sensor! Coasted to off-ramp and called son to come tow me. Well found out yes it was a throttle sensor in the transmission, if it goes out it disengage the engine for safety reasons? Glad I wasn’t in the sand dunes they always show on the RAM ads. A month later after getting it fixed, RAM sent out a letter for recall on the transmission sensor. Dealership gave me my refund! Darn sensors!Had that problem long time ago. Sucks.
The estimate for the same on my Nissan Leaf was $700 CAD. I rush shipped 2 (one as a spare) from China, bought a foil turkey roasting pan to catch the fluids and did the work myself for $56 and 20 minutes of my time. ...and I still have the spare pump even though I sold the car a year and a half ago.I am so done with the big 3 and their engineered obsoleance b$. Just got a quote on replacing a burned out winscreen washer fluid pump (part = $23 @ autozone) for $396.00 lowest quote. The. Entire front bumper must be removed to access it. Americans should be able to repair their owned property, should they not?
...and then the dealer called to follow up the week after I did that to see if I wanted to book an appointment to do it still. I had to break the news gently that I did it already for less than 1/10th the price.The estimate for the same on my Nissan Leaf was $700 CAD. I rush shipped 2 (one as a spare) from China, bought a foil turkey roasting pan to catch the fluids and did the work myself for $56 and 20 minutes of my time. ...and I still have the spare pump even though I sold the car a year and a half ago.
I sensed this would be a problemMy favorite problem on a modern ICE vehicle is sensors. The sensors that are suppose to tell you that there is a problem actually end up being the problem and not what they are trying to sense....
Yeah, they can only buy the official parts, which for the washer pump means also buying the reservoir as part of on module....and then the dealer called to follow up the week after I did that to see if I wanted to book an appointment to do it still. I had to break the news gently that I did it already for less than 1/10th the price.
Yes, ICE has many more parts but that is not the main reason why ICE has more sensors and that failed sensors frequently prevent operation of the vehicle.My F350 had an failed oil pressure sensor. Until it was replaced it would not start. ICE vehicles have more sensors because the ICE engine has more parts.
Yes, I just abbreviated the wall of text into "parts" for readability.Yes, ICE has many more parts but that is not the main reason why ICE has more sensors and that failed sensors frequently prevent operation of the vehicle.
ICE has many more different systems that must operate optimally for proper fuel consumption but more importantly to minimize pollution and keep pollution emissions within legal limits.
Several of these systems operate at extremely high temperature, pressure or both ( cooling system, exhaust system, oil lubrication, fuel injectors) so the sensor must be more rugged and are probably more costly to make.
Just for the engine and you probably have:
Intake Air Temperature Sensor
Intake Mass Airflow Sensor
Camshaft Position Sensor
Crankshaft Position Sensor
O2 (oxygen) sensor (there may be 6 of these) - monitors fuel/oxygen mix
Engine Temperature Sensor
Engine Knock Sensor / Spark Knock Sensor
Fuel Pressure Sensor
Fuel Vapor Pressure Sensor
Fuel Level Sensor
Fuel Temperature Sensor
Water in Fuel Sensor
Oil Pressure Sensor
Oil Level Sensor
MAP (manifold absolute pressure) sensor - adjust fuel/oxty mix due to air pressure change.
NOx sensor (diesel vehicles) measures how much nitrogen oxides are in its exhaust emissions.
Coolant Temperature Sensor
Coolant Level Sensor
Drive Shaft Rotation Sensor
Exhaust Temperature Sensor
Boost Pressure Sensor - monitoring the air-to-fuel ratio
Engine Speed Sensor
DPFE (differential pressure feedback) Sensor
Exhaust Gas Recirculation Valve Position Sensor
