$396.00 wiper pump
Cyberostachu
Manny
Nevada
My favorite problem on a modern ICE vehicle is sensors. The sensors that are suppose to tell you that there is a problem actually end up being the problem and not what they are trying to sense....
Had that problem long time ago. Sucks.
cvalue13
F150L
Fun-employed
is this limited to ICE?
because the Lightning has, for example, a front air dampener with a sensor that goes glitch for a lot of people a lot of the time, with no apparent fix yet
doesnt change or effect the operation of the truck, it's just an annoying alert for no reason except the sensor having some issue
GnarlyDudeLive
Darin
Chicago
Model Y Dual and Cyberbeast
Database Administrator
My F350 had an failed oil pressure sensor. Until it was replaced it would not start. ICE vehicles have more sensors because the ICE engine has more parts.
rodmacpherson
Rod
Pickering, Ontario, Canada
Chevy Volt, Nissan LEAF
Security Architect (IT/Infosec)
I am so done with the big 3 and their engineered obsoleance b$. Just got a quote on replacing a burned out winscreen washer fluid pump (part = $23 @ autozone) for $396.00 lowest quote. The. Entire front bumper must be removed to access it. Americans should be able to repair their owned property, should they not?
The estimate for the same on my Nissan Leaf was $700 CAD. I rush shipped 2 (one as a spare) from China, bought a foil turkey roasting pan to catch the fluids and did the work myself for $56 and 20 minutes of my time. ...and I still have the spare pump even though I sold the car a year and a half ago.
rodmacpherson
Rod
...and then the dealer called to follow up the week after I did that to see if I wanted to book an appointment to do it still. I had to break the news gently that I did it already for less than 1/10th the price.
Cyberman
Adam
F150,F550, Escape
Cybercontractor
I sensed this would be a problem
rodmacpherson
Rod
Yeah, they can only buy the official parts, which for the washer pump means also buying the reservoir as part of on module.
If you have to replace the whole reservoir it requires some time consuming surgery moving a lot of other things out of the way. I bought just the pump and went in via the wheel well.
firsttruck
mx
none
Yes, ICE has many more parts but that is not the main reason why ICE has more sensors and that failed sensors frequently prevent operation of the vehicle.
ICE has many more different systems that must operate optimally for proper fuel consumption but more importantly to minimize pollution and keep pollution emissions within legal limits.
Several of these systems operate at extremely high temperature, pressure or both ( cooling system, exhaust system, oil lubrication, fuel injectors) so the sensor must be more rugged and are probably more costly to make.
Just for the engine and you probably have:
Intake Air Temperature Sensor
Intake Mass Airflow Sensor
Camshaft Position Sensor
Crankshaft Position Sensor
O2 (oxygen) sensor (there may be 6 of these) - monitors fuel/oxygen mix
Engine Temperature Sensor
Engine Knock Sensor / Spark Knock Sensor
Fuel Pressure Sensor
Fuel Vapor Pressure Sensor
Fuel Level Sensor
Fuel Temperature Sensor
Water in Fuel Sensor
Oil Pressure Sensor
Oil Level Sensor
MAP (manifold absolute pressure) sensor - adjust fuel/oxty mix due to air pressure change.
NOx sensor (diesel vehicles) measures how much nitrogen oxides are in its exhaust emissions.
Coolant Temperature Sensor
Coolant Level Sensor
Drive Shaft Rotation Sensor
Exhaust Temperature Sensor
Boost Pressure Sensor - monitoring the air-to-fuel ratio
Engine Speed Sensor
DPFE (differential pressure feedback) Sensor
Exhaust Gas Recirculation Valve Position Sensor
GnarlyDudeLive
Darin
Chicago
Fuel Level Sensor
Oil Pressure Sensor
Oil Level Sensor
Engine Speed Sensor
Yes, I just abbreviated the wall of text into "parts" for readability. :)
android04
Dario
Crete, NE
ts.la
Just an FYI for anybody that might be curious -- Tesla makes their service manual available for free to owners. You have to sign up for their annual subscription to the service manual and renew it yearly, but it's free to owners.
