WINDOW TINT WARNING/Hazard lights stuck on
dbez
David
South Florida
CT AWD
air traffic control
WARNING TO ANYONE ABOUT TO GET THE WINDSHIELD TINTED—-MAKE SURE TECHNICIANS REMOVE THE OVERHEAD CONTROL MODULE (hazard lights and manual drive selection) BEFORE APPLYING ANY LIQUIDS TO WINDSHIELD
Any liquids getting into this module can disable manual drive selection and turn the hazards lights on that you will not be able to turn off until the liquid is removed from the module.
dbez
David
South Florida
CT AWD
air traffic control
Ok, I joined this forum after finding this post. Got my CT AWD last week. Had my windows/windshield tinted and on the way home the hazard lights began to flash and would not turn off. Thankfully, I found this forum describing the issue. I removed the overhead console and disassembled it. Remove all screws, the two sides (with magnets) lift out vertically. The inner plastic housing will separate with a good amount of pulling. (I was a little worried I might break it, but it will come apart) inside there are a few more fasteners and a small ribbon cable connected to the control board. Use a micro screw driver to lift the black tab up and the cable can be removed, allowing for removal of the board and its base. Once completely disassembled I used a hair dryer on low heat to remove any remaining moisture. (Just be sure it is COMPLETELY dry before re assembly). Reconnect to truck and be sure to depress and hold the brake pedal then you should be able to use the hazard button to turn the lights off. WARNING TO ANYONE ABOUT TO GET THE WINDSHIELD TINTED—-MAKE SURE TECHNICIANS REMOVE THE CONTROL MODULE BEFORE APPLYING ANY LIQUIDS TO WINDSHIELD. This should prevent this issue from occurring.
Thank you again to this forum for providing the solution!!!
Art138
Art
Weston,Florida
MYP,Ford GT & FS CYBERBEAST
Can’t they tape the sides of the plastic containing the module so liquid does not comprise that area? It would seem to cut down on extra work.
dbez
David
South Florida
CT AWD
air traffic control
It would literally be quicker to just remove and ensure zero water gets in. It is just snapped into place, just pull it straight down and remove wire connection.
yep. this is why I don't trust most installers with stuff like this.
Ri22
George
Land of Entrapment
M3 CT
Cinematographer
This is true. Mine removes itself about one out of ten times when pulling the visor to the side window... LOL
