Warning: Do not trust MyQ
captn_flatty
NY
55' BelAir wgn 66' Stang Conv 67' Rambler Rebel 87'Benz Rdstr CYBERTRUK, minivan
NYC Ironworker
The garage was already coming down before you entered. It was close, but that's on you to look at it.
The fact that you even question if Tesla is to blame is just odd. This has happened to me when my wife and I were switching cars, but our garage door has a pressure sensor and went back up when it touched the roof....that was also my fault, though.
This should have been a video on "I made a dumb mistake" or "careful because you could make this mistake, too"....that's not how you presented it.
The MyQ integration is intended to open your garage door when you arrive and close it when you leave. This time it did something different, shortly after opening my garage door, it closed again and damaged my vehicle and garage door. It started to close after the door was not visible from the rear view mirror.
The glass roof is shattered and the garage door has damage as well.
This happened to my Model Y, but it could have easily happened in the Cybertruck as well.
Has anyone had this happen, who do you think bares the responsibility here? MyQ, Tesla, or me? I'm pretty sure I know what the lawyers would say.
Sorry about your mishap. My first thought is that it was BAD TIMING because the wheels did not get a chance to cross the SAFETY SENSOR (the green led light). When that sensor light gets any interference the door automatically switches to open mode and cancels any other command. It is put there in case a person or a child walks into or out of the garage or backing in a Model Y while the door is closing.
mkstohler
Mike
scottsdale, AZ
Model X; Lucid Air Grand Touring; CT
Private Equity
I was using FSD so the car stopped on its own and was a little bit short of where I would normally stop. This forced me to do a k-turn. I was looking in the rearview mirror so I did not see if the screen was warning about an auto close or not, however there was no tone and I have it configured to play a tone.
What might have happened. You have the distance to open and close very close. When you did the K turn you probably hit that 12 ft mark and it closed. I have mine set at 25 ft.
DAE1
DAE1
Southern California
CyberBeast & Model S 85D
Precisely. The door didn't close onto the top of the truck car. He backed into a closing door. If it had been the other way around, the ground safety sensor would have triggered the door to open back up as the tires/underbody broke the plane.
Is it truly a plane? I think a long narrow cylindrical region is the more likely profile. This is why it’s possible to just step over the sensor while it’s closing.
Yeah, I think most of them are a low power/grade IR lasers.
Pops
Pops
Houston, TX
MY, CyberBeast
I appreciate everyone's feedback.
I just confirmed when backing into the garage again, the top of the garage door is not visible in the 1. rear view camera, 2. rear view mirror, or 3. side mirrors. It is only visible slightly in the 4. side view cameras. I feel more confident now that there was not much I could have done different in the moment to avoid this.
Who looks UP when backing into a garage? I typically focus on the ground for debris, children or pets.
Tesla Roadster 2nd gen Warning: Do not trust MyQ 20250213_003419 (Large)
AlmostHuman
Earth
Model X, Cybertruck
Human
I have seen this happen on our X (not using MyQ) and the Cybertruck. I think it is when I put the vehicle in drive while shifting rides around in the driveway, it triggers the close door action. It has happened enough times that I watch closely now when moving around close to the garage.
Sucks this happened OP, hope you get things repaired quickly.
DJAlan2000
Alan
Oxnard, CA
I use a WYZE camera/opener system. MUCH cheaper and works with Google Home... It's not 'automatic' (didn't set it up that way), but all I have to do is say "Hey Google, Open/Close the garage door" and, if opening, give it my security code... Does it all from my phone, not through the vehicle so as long as I have my phone and a connection to the Internet, I can open/close it from anywhere!
Also, it was under $100 for both the camera and door opener relay and VERY easy to install and set up... And no, I don't work for Wyze and I don't get anything for recommending it... hehe...
But, it also serves as a 'security camera' that covers my garage as well...
loganthefrst
Logan
Tech
Haha yeah I have never had one issue with mine for 3 years. On my Model Y OR my Cybertruck. Works perfectly. Sorry for the issue you had.
PhilEsq
Philip
Roslyn, NY
Cybertruck ordered and two MB GLC
Attorney
You might want to look at this, which would have prevented that from happening: https://infinity-shield.com/products/infinity-shield-pre-order. I didn't order it, but I thought it was interesting. I would need a set of three.
I use the MyQ app on my phone and keep a remote in the truck. I wasn't interested in paying for the service, especially since I don't necessarily want the garage door to open or close automatically. I prefer to use the remote.
Deleted member 22486
Guest
This has less to do with the myQ app and more to do with your garage door opener and the safety systems it has built into it. It will not shut the door if the garage door safety system believes there’s something in the way. So one of your safety systems, probably the light based safety sensor that’s at the bottom of the door… Or at least supposed to be at the bottom of the door… Versus the myQ app.
Pops
Pops
Houston, TX
MY, CyberBeast
UPDATE: With the details I provided, including the video of the events. Liftmaster/Chamberlain accepted my claim and is going to pay for the roof glass replacement on my Model Y. They took a while to investigate, including looking at event logs. I am thankful to put this issue to rest.
dalton108
Dalton
Lawyer
Congrats! Great outcome!
freyguy
david
Virginia
model y, pre order Cybertruck
Cyber security
That sucks this happened to you. If you are doing smart home and use apple’s homekit. I would ditch myq and install a HomeKit compatible module and use your phone as the key to open your garage door based on location.
