USB C port adapter makes life easier
Gaximus
Mead, CO
Software Developer
That’s actually a pretty good idea, and I thought too bad it doesn’t have a light, did a quick search and found these, they’re not 90 degree(which is a bummer, they might pullout when on accident) but they are lighted. And they are current 43% off.
https://a.co/d/ecqozRH
much better protection from accidentally bending the port too. good idea.
Stuck4ger
Stuck4ger
Cape Canaveral, FL
Aerospace
I’m doing the same for the glovebox thumb drive. I don’t like [edit!] it sticking out where it could be caught or bent.
Stuck4ger
Stuck4ger
Cape Canaveral, FL
Aerospace
Those are USB to USB C adapters, they won’t work in the consoles
I find it annoyingly difficult to see and plug into the console USB port so I got a 90 deg port adapter which stands out both visually and by touch.
https://a.co/d/18l3d8g
Those look nice, but someone should break one open and make sure there are no microchips inside. I've heard of USB cables that look identical to an Apple USB cable, that have a Bluetooth or wifi chip inside as a backdoor into whatever it's plugged into. Full access. Keystroke logging, etc.
Stuck4ger
Stuck4ger
Cape Canaveral, FL
Aerospace
So far I’m only using the USB ports to power my Starlink UPS and recharge my blender!
shopaholic
Gee
East Bay
If you get the magnetic version of the same, will snap (securely) in place without direct visibility.
Stuck4ger
Stuck4ger
Cape Canaveral, FL
Aerospace
Yep, those will work. And you need one with microchips inside if you ever want to draw more than 5V, e.g. to power a Starlink
jahansolu
Jahan
Vancouver
M3, Cybertruck
I do see myself wanting Starlink in the future, but right now the monthly is too expensive and the Mini hasn't been released in Canada.
@Stuck4ger, do you have an example / link of one powerful enough to power Starlink?
