Leaky Window Seals
CyberT1
Andrew
,NJ
2016S,, 2022 X Plaid
Regional sales Mgr
First Tesla? X and Model 3 had similar problems.
Same issue. I don't think Resla really cares anymore about service it's not like it used to be.
seanwpalmer
Sean
Cedar Rapids, IA
CyberBeast
I have the same issue on the front and rear passenger windows. Not sure why it's an issue only on that side and not universal regardless of location. My guess is that they need adjusted or something. Looking forward to what others find out.
Speedr
Dual Motor Cybertruck
FYI, since no one is posting here except to echo the OP, just wanted to mention I don't have this issue. Mine's an early build though. Hopefully it's just an adjustment.
BSDEktelon
Michigan, USA
2024 Cybertruck AWD
Sales Director
I actually just had this addressed by service last week. Funny enough I didn't raise the issue, but they found it during test drive and fixed it. There was definitely a noise coming from there, but absent mindedly I didn't add it. :confused: Regardless....it's MUCH better now. No parts....just adjustment.
Tesla Roadster 2nd gen Leaky Window Seals 1736782662544-gk
CyberT1
Andrew
,NJ
Regional sales Mgr
Received mine in Arp 2024 I do have the issue
Empty tank
Chic
Tennessee
I have an appointment next week but I believe my noise is coming from the windshield. But not really sure, it sounds like a window is open.
Mattkalin
Matt
SW Michigan
My 11 yr old son told me he can hear the air like the window is cracked. But when he taps with window control to roll it down just a tiny bit. It goes away. Weird how when it's all the way up, you hear it. But if you take it down just a little but, it goes away.
My drivers door window leaks air too and its annoying. I find if I move the window up or down a touch it will reseal for a bit. Very Annoying on a 100k plus pickup.. I will have service look at it next time I have it in the shop.
David
Grosse Ile, MI
Cybertruck, Model S
Real Estate
I'll have to give that a try for the short term fix. Thx
David
Grosse Ile, MI
Cybertruck, Model S
Real Estate
Good to know. I will ask them to take a look. Thx
my CT has been better about this than my M3, but this issue happens with all frameless windows.
the fix for me has always been to very lightly feather the window down slightly from the fully raised position. it may take a couple tries at first, but you will find the sweet spot. When you fully warm the truck up, it tends to seal much better.
doubtful that the service center can make any meaningful adjustments unless your seal is somehow way out of whack.
Rusty84084
Fred
Utah
Truck
I have the exact same issue on the driver passenger side windows. When I look in the side mirror, I can see the window bulging. To make the noise go away, I roll the window down one click to take the pressure off the glass, and it seems to help.
