BuddyOtter
- Buddy
- Jan 3, 2023
- USA
- Model S, Model 3
I have the same lightbar and now have an issue after the holiday update. I’ll try unplugging it and resetting to see if that fixes it since FSD is more important to me. Maybe it’ll be fixed in the future.Can 100% confirm it was my aftermarket light bar causing the issue.
After disconnecting the spliced connector and updating again everything worked as expected including FSD function.
I then plugged my light bar in again and immediately all the issues returned. I returned the connector back to stock and everything works as expected.
I believe a lot of the digital rear view mirrors use that same connection point. Something with this last update has made that splice nonfunctional.
Also I’ve had no issues with the lightbar causing any audio problems or errors, until now. I’ll probably switch it out for a functional lightbar if it’s not fixed by spring.
