Cybertruck Wireless Phone Charger Problem Solved
The Tesla Guy
Daniel
Washington
youtubeteslaguy.com
23MS Plaid, 23MY, LR,Order-FoundationCyberTruck DM
I posted my solution to the wireless phone charging problem on my YouTube Channel
Here’s the link.
Links to the products I installed are in the video’s description in YouTube and below…
Here’s the link to my channel as well
https://youtube.com/@theteslaguy?si=Q6XL45-4Iu4i20VS
Product Links:
SANMIDO
Wireless Charger Car Magnetic Charging pads
https://a.co/d/erWMlWn
Taaizau
Flexible Self Adhesive Metal Strip for Magnet
https://a.co/d/dvCb1g0
Thaibear
Neodymium Magnetic Tape
https://a.co/d/3DBef5D
Foronetry
Center Console Cup Holders
https://a.co/d/bPSlUgO
BestEvMod
Center Console Phone Charger Silicone Mat
https://a.co/d/5O0Cbam
Foronetry
USB Hub (Below Rear Screen)
https://a.co/d/id8AZQs
Sandman1962
Sel
Model S , Model X
Good job. I’ve always wondered why a third party just didn’t produce a similar product and we just disconnect the original charger. Should be simple and the cords could be well hidden. I guess I could try too.
Does anyone know if the original charger could be disconnected without issue?
rsdutcher98
Sandra
Davis, Ca
Tesla Model S and Cybertruck order completed, waiting for VIN
Pilot
In previous threads, somebody mentioned Tesla has a fix for the overheating and will do a service call to your house to fix it :)
Kl777yl
GR
Iowa
Model S, Model X, CT
Retired Orthopod
Yup, mobile service is coming to my home Monday morning to upgrade the charger. Warranty fix.
TeslaKen
Ken
Overland Park
www.halocybertruck.com
Currently Occupied
Interesting but I don't want to take away my rear passengers ability to charge. Instead why not use the product that provides ports inside the front center console and run your wires to those ports? Also you could run your wires through the rubber pad and under. You've given me some things to think about...
HunterMt8
Anthony
CyberTruck
IT Engineer
OMG! Just watching the video of the CT being violated hurts. I'd rather get a Mag battery and move on.
LuvOrH8
San Diego, CA
Cyber Truck
This is crazy. So don't use the factory run a bunck of wires have these items sit on top of the factory design and done. No thanks. If anything what I would be able to accept is a version that doesn't need to be wired in spearately. So it sits on top of the OEM, moves your phone to the ideal position to allow it to charge. No added power wires or anything like that. Similiar to the ones for ear pod chargers.
ElectroArmor
Houston
2018 M3 Dual Motor, 2020 MX Long Range
Did they mention a service article, part number, etc? My local service center (The Woodlands, TX) is telling me there is no long term fix and I would have pay out of pocket for a new charger!?!?
81u80x
Los Angeles, CA, USA
Cybertruck AWD Foundation Series (VIN 021xxx)
Please let us know if the fix works. I just got out of a service appointment and they didn’t agree to replace it. Saying they couldn’t reproduce the problem and didn’t know for a fact that the new gen5 charger is fixing this issue.
devdrone6
Dev
Nebraska
Cybertruck, 2023 Model Y
Mine was replaced last week, seems to have made no difference. Still lots of heat, phone still overheats. It’s my only complaint from day one.
Hunter71294
Hunter
KY
24’ AWD Cybertruck
Construction Equipment Rental
I got the new charger replaced under warranty. It’s better but still sucks. I would just use a cable. It doesn’t seem to get super hot but I got 4% in over an hour which to me is useless.
Sandman1962
Sel
Model S , Model X
That really is unacceptable. Does anyone know if we can just unplug the front wireless chargers?
The Tesla Guy
The Tesla Guy
Daniel
Washington
youtubeteslaguy.com
The hub I’m using is mounted under the rear screen. (See the link in my post)
It has 4 ports.
Tesla Roadster 2nd gen Cybertruck Wireless Phone Charger Problem Solved IMG_1845
The Tesla Guy
The Tesla Guy
Daniel
Washington
youtubeteslaguy.com
It has 4 ports.
Tesla Roadster 2nd gen Cybertruck Wireless Phone Charger Problem Solved IMG_1865
My setup leaves 2 ports open for backseat passengers. Inserted USB-A-USB-C adapters to maximize cord compatibility.
Currently driver side MagSafe charger is plugged into the 20v port. I’ll probably use a USB-C splitter to provide faster charging for the front seat passenger.
Known-Background
Pennsylvania
ModelY, Cybertruck AWD
Tesla Service just told me it’s either my case( which I don’t have a case) sunlight, or misplacement of my phone. Does anyone not have this issue? If so what phone do you have? I thought it was because of my older iPhone 12pro. I think one time I saw in the forums a post saying it didn’t happen to their non iPhones and some said their newer iPhones didn’t have the problem.
Tesla also said their new heat sink and charger wouldn’t help the phone heating. And if I wanted it replaced I’d have to pay for it. See this infuriating service note.
Tesla Roadster 2nd gen Cybertruck Wireless Phone Charger Problem Solved IMG_0996
