Charging reduced to 24 A.
Brandon708
Brandon
Downers Grove, IL
oneupsigns.com
Cybertruck, GMC Seirra, Model X, E-Transit, F550
Sign maker
I updated to the latest software update over a week ago. I am not sure if that is the cause but it's really the only thing that has changed in my day to day.
Charging set up.
50 Amp breaker with a 40 Amp charger.
I have tested this with my wife's model X on the same charger, and she is getting 40/40A while the CT is only doing 24/24 A. Not letting me increase the amps.
I know it's cold, but I pull my truck inside to charge and it's still doing this. It charges faster at a super charger though. Can really make sense of it because the X does just fine on the same charger.
Also, I updated the software yesterday to V12 (2025.38.9.6)
Tesla Roadster 2nd gen Charging reduced to 24 A. 1764694283835-mi
Tesla Roadster 2nd gen Charging reduced to 24 A. 1764694303389-qx
MyFirstElectricTesla
SoCal
Benz
Charging set up.
Just a guess: Low voltage?
cadamo001
Chris
Jackson, NJ
Model 3 Highland, Cyberbeast
Sales
Same issue with my FS CB. My appointment is 12/18. I can only charge at 5kw or 24a. Sucks.
Brant9
Brant
Illinois
2024 CyberBeast (Phantom Foundation), 2026 Cybertruck AWD
Thanks for that info. How long did the repair take?
They had it for a week, but the job should only take a day, as long as they have the part and aren’t backed up like my SC was.
Outdoors
Outdoors
North West Montana
S,3,Y,C, Slate Res Hldr
This is one of those pieces that people get pissed off when it fails, or partially fails on other Tesla cars. Many feel it should be part of the battery warranty, yet it isn't. I had a PCS partial fail on a 3 and decided not to fix. Can charge at lower amps at home and still make it work. The number of cars we have dictates lower amp charging anyway. Yet on a Cybertruck this could make charges take a super long time due to size of pack.
I would suggest all get ready for some price quotes post warranty.
Air suspension
PCS
Chargeport replacement
The most comprehensive Cybertruck warranty (for the entire truck) runs for 4 years/50,000 miles. The longest warranty is for corrosion, that's 12 years and unlimited miles! The Battery and Powertrain warranty is 8 years, 150,000 miles.
The power conversion/onboard charger is covered under the comprehensive warranty so all but the highest mileage owners are still under warranty. I know you know this, I just wanted to make the new vehicle warranty coverage clear for those who don't know.
Outdoors
Outdoors
North West Montana
Yes, but PCS is not part of battery nor powertrain. Just letting everyone know and make it clear ya know. Warranty ends at 50k for that item.
https://www.cybertruckownersclub.com/forum/threads/power-conversion-system-failure.46266/page-2. Yeah check that cost. Not insignificant.
Fortunately, the partial failure does not affect DCFC. It's a pricey replacement out of warranty.
CYBERUN
Mark
Palm Springs California
Tesla S, Tesla X and Cybertruck
Charging set up.
Very common problem with CT
I had replaced twice in 18 months.
Time to replace :
POWER CONVERSION
SYSTEM •
48AMP(1777777-12-E)
VOSS 203 - 6mm
CONNECTOR(1051373
00-A)
Tesla Roadster 2nd gen Charging reduced to 24 A. IMG_4526
syburtruck
Matt
Cybertruck FS Cyberbeast
Yep, that's classic PCS2 failure. If you go into service mode, the alerts should tell the story. I'd log that as a ticket ASAP so the parts can be ordered. It's a long job 5+ hours assuming all goes well.
Gaximus
Mead, CO
Software Developer
Anyone with issue also get limited when using power share? It would really suck if power went out and could only provide 5kw of power.
