35” Tires - Anyone running 35's? Any rubbing?
Earthxploration
TCZ
Las Vegas
Tech Professional
Is anyone here running 35” tires? (35x12.5). I’m really curious how much rubbing there is and at what height levels. I see a majority of you stick close to stock specs. Does anyone dare venture off?
Earthxploration
Earthxploration
TCZ
Las Vegas
Tech Professional
Earthxploration
Earthxploration
TCZ
Las Vegas
Tech Professional
DumpsterFire
Utah
Model 3
Mouth Breather
Hey, thanks a bunch again! I saw this video a while back. I understand 37s won’t work but I wish someone tried 35s! I’m purchasing Volk Racing wheels 18x9 0 offset and debating between 295/70/18 (which is slightly shorter but wider than stock) or the 35x12.5 which is slightly taller and wider.
Sounds like you may be the first!
Brandon McNees
Brandon
Grand Rapids, MI
Tesla Foundarion Cyberbeast
Self Employed
QUOTE="Earthxploration, post: 270661, member: 22659"]
[/QUOTE]
CyberChet1234
Chet
Bristol, PA
Cybertruck AWD
Chemist
I’ve had no problem since pickup of Cybertruck in December 2025. Wheel covers have popped off though. Stay away from curbs at drive thru. The rear wheel tirning fools you and peels the wheel cover off with some small damage
The Tumbler
AJ
Alamo, ca
Real Estate Broker
Very much depends on the wheel offset. These fit. 18x9 with an 20mm offset. 35x12 Toyo open country’s. Only rubbing is absolutely tiny at full lock in entry mode. Hear gun and press. Only needed like .25inch or less more clearance.
Tesla Roadster 2nd gen 35” Tires - Anyone running 35's? Any rubbing? IMG_1166
Tesla Roadster 2nd gen 35” Tires - Anyone running 35's? Any rubbing? IMG_1167
Tesla Roadster 2nd gen 35” Tires - Anyone running 35's? Any rubbing? IMG_1124
Tesla Roadster 2nd gen 35” Tires - Anyone running 35's? Any rubbing? IMG_1165
