- May 27, 2024
- SE Michigan
- Cyberbeast
Even if everything is tight, vertical displacements and rotational moments will be less noticeable if spread out over time by a compliant interface.Huh? If you are using quality towing gear, everything should fit tightly enough that you don't feel any jolts or jerks when going over road imperfections. If it was jolting/jerking I would want to know about it because that implies something is wrong.
