Switching from FSD to Cruise Control
Mystery.Shadow
Michael
Cumberland, Maryland
2024 Cybertruck AWD
Please excuse my n00bishness, I just picked up my Cybertruck yesterday. I do have FSD and it works wonderfully! But how can I switch from FSD to Traffic Aware Cruise Control and back again?
I tried single right wheel click, and double click.
Once FSD is engaged, it doesn't seem to want to "let go". What am I missing here? FSD will disengage as predicted, but I cannot seem to get Cruise Control to run after I FSD has been activated.
Any assistance?
aeroguy
VA
Try settings->autopilot->select TACC. You have to be in park to then go back to autopilot, but you can switch to TACC while driving.
Mystery.Shadow
Mystery.Shadow
Michael
2024 Cybertruck AWD
Is there a way to switch from FSD to TACC and back while driving the Cybertruck?
Don't want to Park every time.
Sometimes I actually want to drive...
Gaximus
Mead, CO
Software Developer
Unfortunately not, and this isn't just a CT issue, it's a Tesla wide issue. It would be nice to choose which one I'd like to enable from the steering wheel while driving, but its probably a legal issue(and I can see why, thinking I put it in FSD and accidentally putting it in TACC and letting go of the steering wheel). Or just be able to disable auto lane changes for the rest of the trip, the number of times I've had FSD try to change into the Expresslane(Double white lines) and have to keep disconnecting, is so embarrassing. We will be the opposite of the BMW meme with turn signals always turning on and never turning.
Also, be aware that the basic auto-pilot is still not yet available on the CT.
L3it3R
Chris
Maryland
After having FSD for years in my other Teslas, and only TACC in the CT for the first 6 months of ownership, personally I'd never go back.
Ddanis60
David
Omaha, NE
2019 MXP, 2022 M3P, 2024 Cybertruck awd
Retired Military
There is a setting ā€œminimize lane changes for current driveā€ that I use when driving on the highway in metro areas to avoid just that. It works well and should only change lanes to absolutely follow a necessary route. If you don’t have anything in gps routing, it should stay in the lane you are in when selected. If you do want to change lanes, the blinker will start a lane change. It’s really close to the same functionality as enhanced auto pilot, before fsd came out. I prefer it sometimes to have a middle level of control. And you can enter and exit this mode while driving in the autopilot tab. It’s not perfect but sounds like what you might want or at least help. I’m sure you’re aware as you’re active around here, but also just for anyone else reading.
Djinndjinn
Pennsylvania
Models S, Cybertruck
you could try creating two profiles-one profile is FSD, and the other profile is FSD turned off a.k.a.TACC. Name them whatever makes sense to you. You can switch profiles while you’re driving, but I would just caution you to make sure that you have the seat adjusted and mirrors adjusted so that they’re almost identical, otherwise in the middle of driving your seat and mirrors will be moving. That could be it safety issue. Other than that, it seems to work.
Mystery.Shadow
Mystery.Shadow
Michael
2024 Cybertruck AWD
That's brilliant! Will have to try that.
Just wish we could change by single-click and double-click. Not unlike some of those vehicles with stalks!
CarMan ElecTruck
Other Earth
LeftFoot RightFoot
However.. you will get the ā€˜nag’ to try FSD while you don’t have it activated.. this annoys me.. and it just stays on the display for some random amount of time..
Lame
Stuck4ger
Cape Canaveral, FL
Aerospace
?this works for me, too
