- May 27, 2024
- SE Michigan
- Cyberbeast
The Gateway monitors the utility side of its disconnect switch to determine when to change state. Gateway controls the island state independent of utility state. The Gateway uses the state of its disconnect switch as an input to the signal that it publishes to the Cybertruck to enable power export.Where would it get utility power status if it wasn't the utility side of the gateway?
In this setup, there really isn't an island concept. It's utility on/ utility off.
The Enphase then just sees power, sync and augment.
And that where it appears the Powershare can see the extra power and assume that something isn't quite right and jumps ship.
Cybertruck only exports into an island so Gateway reconnecting requires dropping Cybertruck export before reconnection. Solar only exports into a live circuit (unless they are grid forming with their own controller).
