ideaXfactory
I passivated my Cybertruck today and it worked well. I decided to use CitriSurf 2310, which has a higher viscosity, so works better on vertical surfaces.
Though I have passivated Stainless Steel using Nitric Acid in the past, the CitriSurf 2310 seemed a little easier to keep wet on the surface, and is safer to use.
It was a bit tricky to apply, but I followed the instructions and kept it moist on the truck for about 25-30 minutes, and then started rinsing it off. I ended up rinsing it and wiping the entire truck off with microfiber towels several times, mainly because I absolutely didn't want to use glass cleaner as a neutralizer (as has been suggested to use on this forum along with BKF), and because clean water is what is recommended by the manufacturer.
Now that it's passivated correctly, fingerprints are even less of a problem, see video... This is how I expect stainless steel to be... very, very hard and resistive to corrosion of any kind.
It should also be free from any/all iron contamination now.
