- Banned
- #31
Looking at the slow motion part trying to climb the hill, notice how little articulation the suspension has. The front almost looks static. Had a wheel in the air off this minor divot.
The Dual Motor Cybertruck has front and rear locking differentials. They just haven't been activated yet.I don't understand... How can a software update give you lockers ? You either have them or you don't. Unless it has a motor at each wheel then in that case it would not even need diffs.
pardon my ignorance because I haven't offroaded seriously--just easy trails with my taco off-road --but I was always under the impression that, if you don't have lockers, and one wheel is off the ground, then that wheel gets all the torque, so you spin and you get nowhere. if you have a locking diff, then power will go to the left front wheel in the video, and that may be enough to get you over--which didn't happen in the video. as I understand it, AWD teslas typically use braking to "lock" the free spinning wheel, and maybe that's not optimized or implemented yet in the cybertruck in the video, but I was also under the impression that that was an imperfect solution to the problem even when it is implemented.what does âoffroadâ mode do, if not make it send power to all 4 wheels?
if its true that the other 3 tires were in contact, then I still donât get pointing to lockers.
This âSubaru made it hahahâ talk only shows more inexperienced 4x4ers on this forum. ⊠Or should we talk drive dynamics of a 6600lbs 18 ft long vehicle vs 3300lbs 15 long vehicle ?
obvious that different vehicles do things differently, that wheelbase matters, etc.(Yes, sub has shorter wheelbase butâŠ)
mom not trying to suggest this video and its context is the sum total of the Cybertruckâs âratingâ offroad.pardon my ignorance because I haven't offroaded seriously--just easy trails with my taco off-road --but I was always under the impression that, if you don't have lockers, and one wheel is off the ground, then that wheel gets all the torque, so you spin and you get nowhere. if you have a locking diff, then power will go to the left front wheel in the video, and that may be enough to get you over--which didn't happen in the video. as I understand it, AWD teslas typically use braking to "lock" the free spinning wheel, and maybe that's not optimized or implemented yet in the cybertruck in the video, but I was also under the impression that that was an imperfect solution to the problem even when it is implemented.
can you help me to understand how the 6600lbs, in a truck with this hp/torque, aired down to 30PSI, is such a downside for it in this scenario that it just brushes away the other factors at play?The Cybertruck is a 6600 lb vehicle with a long wheel base and sporting road efficient "all-terrain tires." What do people expect???
On roads, Tesla has one of the most advanced traction control systems out there. Try to spin the rear tires. It's obvious that the motor has enough power to easily do so. Try to do a donut, the vehicle just won't do it.I get your sentiment but it's natural for people to compare things. Essentially every car youtube channel exists to make comparisons. I could walk up that hill in $5 shoes from the thrift store but it doesn't change the premise of why people make the comparison to other vehicles - some buyers want to go remote places and bring their family/things along with them.
They expect this truck to be capable and to see it fail when another vehicle most would consider less capable makes it is tough to watch. You can say weight or length and yes they play factors, but that CT not getting up that hill was far more software/systems kicking in and restricting the slip then anything else which is why I have hope they'll be able to fix these things. This is Tesla's first vehicle designed to go off-road, they're going to need to tweak things.
And that's the MOST AWESOME THING ABOUT TESLA!So tesla just installed some lockers in the CT without thinking about whether or not the diffs / cvs could handle it or when and how to use it ? And they just sell off vehicles that have features/selling points that are incomplete ?
trucks from the 90s had e-lockers. Its not rocket science. Tesla obviously shit the bed on thisAnd that's the MOST AWESOME THING ABOUT TESLA!
They aren't complete. They are forever changing. You have to get rid of that old world thinking.
The hardware has the ability. It's now time for the software folks to have some fun with it.
A Tesla is not like any other legacy vehicle where you know what features it will have in 10 years, because they are the exact same as the day you bought it.
I agree that e-lockers are not new, at the same time there is a tremendous amount of torque that is instantly available that was pretty unheard of in the 90âs.trucks from the 90s had e-lockers. Its not rocket science. Tesla obviously shit the bed on this
I agree that will all the torque the CT has it will absolutely destroy the diffs and probably the cvs. Ifs/irs does not do well locked. Even if a rubicon came with 1000 lb/ft of torque it would snap axles and blow ring gears and dana 44s are much beefier than the CTs axles/suspension. So perhaps tesla found themselves in a bit of a pickle with this one because they know that customers are going to be destroying their new vehicles.I agree that e-lockers are not new, at the same time there is a tremendous amount of torque that is instantly available that was pretty unheard of in the 90âs.
It could be a possibility that Tesla is trying to have the software recognize when to safely engage/disengage the lockers so that torque doesnât damage them. It may not be a simple on off switch. If theyâre trying to make it to where the software can detect when to automatically engage the lockers, that could be a whole other issue.
As others have mentioned, that is one of the beauties of owning a Tesla, it keeps getting better. ?
