Dangerous Trim Issue
Venusfly
Jochen
Ann Arbor
Raptor, H1, early order Cybertruck
I noticed a few days ago that the boomerang upper window trim on the drivers side seemed to stick out a hair at the front lip. I checked it and pressed it back in. Knowing that I had a service appointment today at Tesla, I added it to my list of topics.
The advisor called their CT specialist, he inspected it and stated that “the trim piece was starting to separate from the base, and that they will order a new one to get it replaced.” No further comments were made.
Bonus bummer for me, the truck is wrapped, so I made an appointment with my wrapper to coincide with my next Tesla appointment in 30 days. Who wants to drive around with a silver lip on a white truck.
I ran a quick errand tonight, and while merging and accelerating on the Interstate in normal traffic, at about 70 mph, I hear a large ripping sound and the metal panel liberates and flies into traffic behind me. I was not able to stop as I was in the middle of a highway split. I rolled the window down and felt for it, and yes, the trim was gone. I looped around, next exit off/on, back to my original exit off/on, stopped with the hazards on, and located the piece, by that time run over multiple times with tire marks on the white wrap. I threw the piece into bed and drove home.
So the trim piece did not come off as one would expect (as the bed sail panel did on some trucks). The stainless portion separated from the plastic subframe that mounts the trim panel to the truck. The subframe is still there, all clips are in, and you can see the glue spots that once bonded the metal to the plastic, 17 to be exact.
I scaled the metal portion, 5 pounds. So imagine, a 9 foot long 2 inch wide 1/16th thick piece of stainless steel in the shape of a boomerang liberating at 70mph on the Interstate. This could have decapitated a motorcyclist behind me, or could have gone through someones windshield. Someone was lucky tonight, including myself.
Might as well throw longswords out the window. This part is simply glued on, something is very wrong here. This is a major flaw in my book. I had my CT since May, just rolled 10,000 miles, and drive it sun rain sleet or snow.
Not a good situation. Has anybody experienced
this? a
Tesla Roadster 2nd gen Dangerous Trim Issue IMG_3193
Tesla Roadster 2nd gen Dangerous Trim Issue IMG_3192
kpanda17
Tesla Model 3RWD, Tesla Model MYP
Have you checked the other side?
You said you had it wrapped, I'm wondering if someone got overzelous with post heating and it affected the early adhesives tesla was using.
Good point, rhe wrap installer could have caused this
Just sayin
^ this.
I guess the lesson here also is to not drive 70mph when know your trim price is dodgy.
I believe Dirty Tesla had this happen, but his only bent backwards and did not dislodge.
The common issue is due to the trim piece being anchored at the front by a bolt, which is adjusted to make the trim flush with the body. It’s secured with Locktite, but an insufficient amount can cause it to loosen.
The problem with this, and the sail appliqué also, is that becoming slightly loose can get it to catch the wind, and then physics takes over.
tmeyer3
Trevor
www.meyerwine.com
Computer Scientist, Vintner
Good to know, but on my truck there's a nut, albeit a small one, one each end of that boomerang piece. Did that break or just come all the way off?
By the way, love the wrap!
igs
CT, MX, MY
** trim obnoxious word salad **
Actually it's bolted on. Are you sure your wrapper didn't take the nut off and forget to put it back on? This issue seems to only affect wrapped trucks. I wonder what the common denominator is.
Venusfly
Venusfly
Jochen
Ann Arbor
The wrap was done last June, so too long ago to cause an issue now. The last one that was active in that area was Tesla Service when they did the wiper motor mod, and installed the new assembly that ended up with its base not being completely flush with the windshield. Maybe it put some undue pressure on the leading edge of the boomerang, that over time started to separate the glue?
The tech today also spoke about the road salt causing havoc on the wiper sprayer valve, maybe salt (we have more salt on the roads than we have ice and snow) was also a contributing factor to the ungluing?
tmeyer3
Trevor
www.meyerwine.com
Certainly could be, may never know. I'm more concerned about where the bolts/nuts went. Weird
sys700
Rod
Portage, MI
Foundation Series Cyberbeast (August 2024 - 26###)
this? a
If my trim piece were coming off, there's no way I'd be driving 70+ mph.
ChiTownCT
CT
Chicago
CYBERTRUCK
Let me chime in here, this has NOTHING to do with the wrap as my wife had the same thing happen on the passenger side of the truck going 20 MPH on a side road. When I picked up the truck in June of last year, I made sure to tighten the bolts, but come to find out it is indeed two pieces, one is held by a bolt and the other by glue. When I mentioned to SC we should change out drivers side just in case, SC they stated they are unable to change it until it comes off.
SO in this case, if my drivers piece decides to fall off and hurt someone I will sue.
