CyberRack -- stowable Cybertruck bed rack (stores in vault)
Vertiburd
George
cybertruck
enginee
I've designed an overhead truck rack (CyberRack) for the Cybertruck that stores in its vault. Normally you don't see it, but when you need it, it sets up fast taking advantage of the rear sloping roof on the cab to allow for an extended front crossbar making its overall length over 100 inches. It should weigh about 85 pounds (Lighter if made from aluminum) and be easily removable. I think i can also design it to allow the sub-trunk to open when the rack's stowed.
Tesla Roadster 2nd gen CyberRack -- stowable Cybertruck bed rack (stores in vault) Cybertruck rack Cybertrack Stowable bed rack
Coolbreeze704
Bruce
Troutman,NC
GM Manufactured Homes
Looks great. Do you think you have any issue with Tesla on calling it a CyberRack? Would think they have that copyrighted already. Good luck though. Should do really well.
Gurule92
Colorado Springs
MYP
"Cyber" stuff
Nice rack
Gurule92
Colorado Springs
MYP
"Cyber" stuff
That's a problem for future vertiburd lol
COLAB
Bruno
Carignan
colabconcept.org
Nissan Frontier
Product manager IT services
Good idea, with a little more reinforcement to prevent vibrations maybe but it's a good start! To be continued ! ;)
Newton
Newton
East Bay Area, CA
p̶r̶i̶u̶s̶ c̶,̶ y̶o̶t̶a̶ p̶i̶c̶k̶u̶p, ⼕丫⻏?尺セ尺ㄩ⼕长
cool idea, I would personally prefer it in a bag of just straight pieces that u take out and put together.
or maybe just the cross members, so u still have a good amount of flat bed area.
anionic1
Michael
Estimator
So when it’s stowed you basically have to deal with awkward chunks of metal in the bed?
DMC-81
Dana
Transformers Camaro SS, 1985 Corvette Z51, Dodge Magnum R/T, 1981 DeLorean, CT reservation
Nice idea for part-time hauling of long items!
rodmacpherson
Rod
Pickering, Ontario, Canada
Chevy Volt, Nissan LEAF
Security Architect (IT/Infosec)
Nice start. Once the real truck is available to measure, I would add braces that attach to the hardpoint roof rack attachment points to give it better stability.
fhteagle
Telluride, CO
2013 Volt, CT Res x2
I like the concept in the deployed position, depending on just exactly how sturdy the frame is. In stowed position, not so much. Either needs cover plates to smooth it back out or the widths need to be adjusted so it will go truly flat pack on the bottom of the bed.
Also not seeing that much advantage over semi-permanent sail side extension racks, similar to the one at the lithium refinery opening. Just my honest opinion, though without having seen either in the flesh yet.
Vertiburd
Vertiburd
George
cybertruck
enginee
You could keep it stored in the vault, or you could keep it in your garage till needed.
