Bed Cargo Divider issue (alignment)?
Vesder21
Dave
my issue is that my latch won't shut flat no matter how much pressure I put on it.
anyone else or am I not doing something correctly?
Tesla Roadster 2nd gen Bed Cargo Divider issue (alignment)? tempImageewcrS5
Tesla Roadster 2nd gen Bed Cargo Divider issue (alignment)? tempImageVEH6s3
TownBiz
AWD
it should definitely go flat when you push it all the way down (assuming the connectors are aligned on both sides of it in the vault)
Jim Waller
Los Altos, CA
I know this response is months late but I have the same or similar issue. I had to literally kick down hard on the top to get both sides to seat. The bed height too high or the divider too tall. Didn't want to grind the bottom of the divider so I took to service. They sent a new one - same issue. I took a pipe wrench and carefully did a scary slight bend on the outer latch downward. This helped mine, but it doesn't seem like Tesla engineering allowed for normal fitment tolerance.
JesseDGreat
Jesse
San Bernardino, CA
2024 CT AWD Foundation, 2022 Model S, 2023 Model 3
Finance Manager
I had the same thing. Ordered the divider before I got my CT. Received it before I got my CT. THen I get an email from Tesla telling me that they found and issue with the one I ordered, and they were sending a replacement. Before I received the replacement, I tried my original and could not install it past the first 1/3 of the bed. Got my new one and the exact same thing. I emailed Tesla and they saw I had a service appointment for today and told me to take both to the service center and show them. I did and they agreed that it was an issue. Waiting to see what happens when I go to pick it up. Hopefully, I get a new one and everything gets fixed ( had a nice sized list of issues ). The replacement was exactly like my first one. The first one did NOT have the complete circles for pegs as I understood this was the issue. But I think the issue is the feet on the divider. They wont go flush against the bed past the 1/3 front part of the bed.
CyberFreak
CT
Many (most?) of the bed plastic currently out in the wild have a slight bow in them.
I took mine to service and they agreed so they ordered a brand new bed plastic and unfortunately the new one has the same bow.
It is very minute and you likely would never notice it unless you got a bed divider!
Not sure how they will fix this but there are 2 options: a) fix the bottom of the divider to have a slightly larger tolerance for variations in the bed; b) recall the beds and replace them with fully flat ones.
Cyberer
KK
Omaha
2014 S, Multiple Classics
Cars
I bought this bed divider net today. I’m thinking it will fit perfect right behind the trunk easy to unhook for larger items, but provides a barrier for smaller loads, like groceries. Got this hold-down net too.
Tesla Roadster 2nd gen Bed Cargo Divider issue (alignment)? IMG_5934
Tesla Roadster 2nd gen Bed Cargo Divider issue (alignment)? IMG_5933
rjhoskins
Ryan
2023 Model S Plaid 2024 Cybertruck AWD
Please do a followup post with these items "in use" when you receive.
agordon117
cybertruck foundation awd
it's a shame that this is still an issue with the new divider. The fix is quite easy from a manufacturing standpoint. They just have to increase the distance from the bottom of the rubber feet to the bottom of the aluminum part of the divider so that it can clear the bed liner. Someone took a bandsaw to the bottom of theirs to get it to fit, but I might try a dremel so that I can just cut the sections where the bed divider would touch. It's a really useful accessory in theory, but it needs to be designed the right way to allow for the large tolerance in the bed liner height.
popz41
SoCal
Beast
Service center tried switching out the bed on me, but it was still bowed in the middle. Eventually they reached out to engineering, and they "adjusted bedside wall assembly", now my divider works all along the bed.
TickTock
Phoenix, AZ
Electrical Engineer
Any update? I just received my divider yesterday is this issue persists. In my case it is off almost 1/4" and no amount of sitting on it or kicking it will get it to engage the bed rails. Same from the tailgate to the cabin.
Tesla Roadster 2nd gen Bed Cargo Divider issue (alignment)? 1720734419534-t7
Tesla Roadster 2nd gen Bed Cargo Divider issue (alignment)? 1720734499855-as
mdcoleman
Matt
Seattle, WA
2024 CyberTruck FS (123D) (124XX VIN)
Construction Manager / Contractor
Completely irrelevant, but I just got my divider yesterday and alignment was not perfect, even with the bed liner out of the way. I just set mine in place where the bins were secure, pushed the handle down (not overly difficult, but pins are not locked into rail holes), and I’m good with it lol.
Tesla Roadster 2nd gen Bed Cargo Divider issue (alignment)? IMG_9120
Guylouis
Guy
F.S. CyberBeast, XP, YP, 3P
I have the same issue. It seems that the rear part of the bed plastic cover is not properly tightened down and is sitting a bit higher than the front portion. This elevation difference doesn’t allow for the vault divider to properly latch into place
Guylouis
Guy
This is exactly how mine is
JesseDGreat
Jesse
San Bernardino, CA
Finance Manager
No update. Im going to put in another service request but this time Im going to point out how my bed is higher and not aligned. THe first time, I thought it was the divider. Ill keep you updated
