Any recommendations on windshield washer fluid?
Digistrator
Bill
Palos verdes, Ca 90274
Self employed
Additionally, as I was running the wipers, got the notice that the fluid was low. The blade left streaks across the top of the arc, leaving a gap where the sprayers are. I hand washed the the wind shield and felt depressions where the streaks were. No scratches just perceive able depression. Anyone else?
I find it difficult to keep the windshield clean, there’s always some smudge that appears in direct sunlight even after a (what I believe to be) spotless cleaning. Recommendations? Thanks!
jf64k
I've been a BMW Washer Fluid Concentrate guy for years.
It works amazingly well, and it's inexpensive ($2.52 a bottle).
Product Detail | Shop BMW USA
I mix mine to make two gallons of fluid. Nice thing is you can mix it stronger if you need more anti-freeze capability.
It's also available at Mini dealers. Same price.
Tesla Roadster 2nd gen Any recommendations on windshield washer fluid? 83192221702-01_6463
Gaximus
Mead, CO
Software Developer
I try and avoid the windshield wiper spray when possible, for any vehicle. Usually just makes a mess, works good when in snow and that kind of dirt. But hit a big O' juicy bug and turn on the wiper, it going to be harder to see after. For cleaning the window, I've gone to just a spray bottle mixed with 70/30 water alcohol. Works really well, and doesn't streak, because of how fast it evaporates. Sometimes you might have to scrub a little harder since it doesn't have any of the soaps other window cleaners have, but you also don't get the streaks from that they leave from the residue either.
I'm a heavy believe in water. Just be careful in freezing temperatures.
It has the advantage of leaving no residue.
webwrangler
Seattle
Tesla Model 3, Tesla Model Y
I was getting that film that the wipers spread across the window that disappears after a second, but still causes an intermittent haze on the view. I tried replacing the wipers, which helped a bit but not really. I complained about this to a coworker and he told me to clean the window really well with a glass polish. Then clean the wiper blades, pump out all the fluid in the wiper spray system and switch it to 20/10. I did all that and I must say it’s much improved. It’s early days for me so maybe the haze will come back when the glass gets dirty again, but things are definitely better. I got the 20/10 at O’Rileys. It looked expensive at first, but it’s a concentrate so…
I don’t use the RainX washer fluid, but I did treat the windshield with the RainX coating. It definitely helps.
Gaximus
Mead, CO
Software Developer
So this is awesome. I was actually looking for concentrated windshield cleaner a while back on Amazon with no luck. I figure you’re buying mostly water in the one gallon variants. What temperature is the antifreeze rated too?
jf64k
I'm not at home, here's a pic I grabbed from the net. AF temp varies with concentration:
ETA: This stuff really works well. I just drove a BMW i3 and the windshield was filthy. This stuff cut right through the dust and left no streaks.
Tesla Roadster 2nd gen Any recommendations on windshield washer fluid? 83192221702-2
RickJ19Zeta8
Wisconsin
Tri-Motor Cybertruck (soon_TM), Model 3
Adams Windshield Washer Fluid
No dye, good to -25F, cleans bugs, doesn't foul the fill sensor, works great, and its a reasonable price even with shipping if you order enough of them. Especially if you order other Adams products or over $115 of total items.
I've mixed my own, I've used Nexzett concentrate, BMW concentrate, McKees concentrate, and this is by the far the best value for cold weather vehicles. I use it year round.
I've been using the Nextzett Krystal Klear concentrate mixed with water and abut 25% alcohol in my Cybertruck (actually it's about a 50/50 mix of what the truck was delivered with).
My impression is that it needs more lubrication. It could be it doesn't work well with the factory mix or I have a bit too much alcohol in there, and not enough concentrate, I'm not sure. Maybe I'll try adding some more concentrate.
Nidavellir
AWD CyberTruck
Are you using the alcohol to keep it from freezing? I use it 1oz mixed with 1.5 gallons of distilled water.
