Adhesive phone mount advice
AB3
Cleveland
Cybertruck AWD
Hello y'all, I stream live a lot while I'm driving and currently have one of the ones that clips to the corner of the display but it's a cheaper one with a weak magnet and it shakes a lot. I just was gifted by a friend a magnetic phone mount/charger that is made to be placed right on top of the dashboard that's seems a lot sturdier with a stronger magnet. But I'm wondering if the adhesive will damage the dash or leave marks (I have an AWD so no alcantara) and if there is something safe to put in between the dash and the mount. Do you guys think I'm good to just stick it on or any ideas for a way to use it without sticking directly to the dash? I really like the dash mounted solution because you can get a full view of the interior while still using the front facing camera vs having to use the wide angle back cam.
edsonbarron
Edson
Kansas
cybertruck
4th Tesla using magbak. It’s the only screen mount that isn’t flimsy and doesn’t vibrate
AB3
AB3
Cleveland
Cybertruck AWD
Does the magbak allow the phone to be mounted horizontally? My current one does but it puts pressure on the phone so it's not quite flush which I think it what makes it so prone to falling when I hit a hard bump. Well that along with the weak magnet.
edsonbarron
Edson
Kansas
cybertruck
its angled towards the driver so yes you can put it sideways with no issues. It’ll only fall if you have a weak magnet on your case.
Reactions: AB3
shawnlab
Shawn
Mount Ulla, NC
Cybertruck Cyberbeast 2024
Behavioral Architect
I did this. Got a tray that sits behind the screen that has those tripod mounting screw, then got a male to male adapter for those tripod screw holes, then got a magnetic phone mount for a tripod.
Tesla Roadster 2nd gen Adhesive phone mount advice Screenshot 2025-02-19 093313
shawnlab
Shawn
Mount Ulla, NC
