- JB
- Nov 22, 2019
- Australia
- Tesla
- . Professional Hobbyist
I thought I'd make a dedicated thread for this discussion to share thoughts on how the structural pack design works, in response to discussions on various other threads.
Model Y 4680 Structural pack as reference
These are some pictures I grabbed from Monroes teardown the 4680 to get an idea of the of the side buffer setbacks and dimensions on the MY. I think on the CT we should be able to use the same factors, to at least get to the ball park of the max space available for 4680 under the CT. These side buffers are for side impact protection of the battery packs, and they also offer a progressively rigid side impact protection.
Looks like about 175mm (7") between the cell and the edge of the pack. Which is fairly substantial. It looks like the pack screw holes are inside of the red cabin frame, and it slots up onto the grey cabin frame and cast. The red frame is about another 40mm, so about 215mm (8.5") from the outside wall to the first cell.
CT Pack cell Area
Using those setbacks I end up with a pink box that looks like the below, and inside that a "naked" 120kWh pack on a single layer that is this big:
It's pretty clear that a single cell high 120kWh pack does not reach the size capacity limit on the CT floor (which is the pink box around the cells), given that we now know that the battery can also extend under the vault cover in the rear (which is actually a bit further back than the pink box), where the "hump" known as the penthouse also is housed. We also know from the x-ray pictures, that the original battery "could" even extend under the front and in between the front wheel arches as shown by the pink box to the left.
Just for comparison this is what a single layer 185kWh looks like still staying within the same setback bounds as a MY design:
Now this is "just" naked cell density spacing without any structural or cooling components going through the pack. This could take up an extra 20-30% of the surface area depending on configuration. Especially if there is snake cooling between the cells that also has lines that have to be routed to the front cooling system
Edit: But if that cell cooling is no longer between cells anymore, rather just from the cathode side on the top of the pack. it would mean that it wouldn't add to the cell foot print area (like on 18650/2170). This is proposed here
Because the cells are stacked and attached, by the both top and bottom of the cell, by the structural layers, it would also form more of a structural webbing between the top/bottom layers. It's important to point out that both the cell wall of the cell (which is also a bit thicker than a 2170) and the pink foam that binds the cells together transfer load. The foam also helps maintain the cell wall geometry and stops it from buckling, it's also likely a fire retardant, to reduce fire propagation, and also adds some thermal capability as well.
The MY used 4 packs, which means three internal ribs separating the packs:
Each separating rib being about 40mm wide (1.5")
So just using the above, it's likely that they could get around 165-175kWh in one single layer, and still stay within the constraints of the pink box. BTW 165kWh at 400Wh/mile is well... around 420miles.
Now if we add 20% cell improvement over time we get 500mile range or a 200kWh pack.
But we do so within the same confines of the 165kWh, which fits within the 185kWh footprint shown above, and all without needing a dual layer pack at all.
This is more important than it might first seem, in that a structural pack is unlikely to ever be dual layer, because both the top and bottom steel "skin" layer of the pack form the structural chord and the battery cells themselves the "core" webbing. Now because the webbing is attached to the two steel layers, they can transfer load from front to rear. This is because like a truss, one layer skin goes into compression, while the opposite skin goes under tension, while the core keeps each skin geometrically separated. The core is compressing the cells, every time the top and bottom skins are subjected to forces.
Note this diagram will change depending on where the forces are applied, but the principal of the sandwich structure is the same.
With TWO layers of batteries however, there would have to be a third layer in between them, which in turn means that the lower layer battery will carry the top layer battery, but unless it is pre-tensioned, the top layer won't add much structure, and bottom will carry both as the two panels of cells "slide" over each other.
That's why you don't see many "truss" designs that use two trusses stacked on top of eachother.
This is because with core compression the vertical forces need to make it through both the vertical and diagonal webbing from the very top skin to the very bottom skin (chord). If they don't the top horizontal skin chord can't go into compression and the bottom skin chord can't go into tension (as per above truss loading), which is how load is transferred from one side of the truss to the other to the anchor points (red triangles).
There's also a bunch of cooling, cell terminations, and heat that needs to be considered when double stacking, and in particular assembly times etc. There's also height limits in the rear seat to consider, and the fact that the "cabin frame" would need would need to structurally connect to both the single and double layer pack, using the same cabin frame design. The difference in the skin heights means loads will be significantly different between a double and single layer pack.
Making two cabin frames, and possibly even two casts sounds expensive, just to have a longer range pack, which given the cell area above seems unnecessary anyway. From a battery perspective I seriously doubt we will need, or ever see a double layer "structural" pack. And the CT needs a structural pack for it's cabin design, otherwise there's no point making the pack structural in the first place, otherwise the pack will not have the desired effect of reducing the vehicle mass by displacing other load bearing structures in the vehicle.
You could do some "backpack" style under seat battery storage, but I don't think it is necessary given the space in the 1st layer, and adding cooling and connections to the backpacks is also non-trivial for the extra capacity they provide. Let alone they detract from interior space.
For example in the MY the open space under the front seats is quite generous and allows one to put feet underneath. In the CT the rear seats fold up (like the F150) to make a flat floor loading space as we have seen from the pictures. This is because that penthouse is behind the rear bulkhead under the bed, and not under the rear seat like in the rest of the SEXY range.
Hope this helps visualise what is going on.
CT Pack cell Area
