4680 Battery Anode at Giga Berlin
Dids
Les
Massachusetts
04 Tacoma, 23 Cybertruck
Self
If this 4680 pack was in Berlin wouldn't it be for ModelY? Does ModelY get a structural pack? Perhaps cooling for non structural 4680 and structural are different....
They could also use aluminum for cooling. Most heat sinks are aluminum. While aluminum is not quite as good a thermal conductor it might not matter for 4680.
Battery heat is from internal resistance and the shortened electrical path via shingled contact surely reduces internal resistance. Indeed this has to be true, If heat has an easier means of escape from the cell than electrical resistance does not increase, then less heat is created. End result is a pack that can charge faster and creates less heat needs less thermal management and maybe doesn't need copper tube.
OneLapper
NE Conn
BMW 328d Sportswagon
The 4680 pack pictured is definitely the "structural" pack, and if that is a MY chassis, then the MY is getting a structural pack. Plus, the body in white has no floor. The battery pack's top lid is the body's floor.
And I agree with everything else you wrote. Less electrical resistance, less heat, less cooling efficiency needed.
CompMaster
Tri CT
Yes, MY is first the get Structural pack with front and back casting.
According to US8758924B2 " Exemplary materials for the cooling tube include metals such as aluminum, an aluminum alloy, steel or copper."
Does not specify which or the combination of which they use.
From all the packs I tear down to the cell level, which includes removing the cooling ribbon. All have been aluminum that us covered with the same damping material as mentioned in the number above.
Only one different is the LFP Packs, I have not touched one yet, but Sandy has and that is a complete different beast, and it's a Beauty!!
Ogre
Dennis
Ogregon
It is structural, it is on the Model Y. Photo below is same pack, on the vehicle.
In another place on the tour, they have the seats bolted directly to that formed metal which is right atop the battery. Apparently they now bolt the seats and console onto the battery pack before the Body is attached then lower the body down onto the pack with the seats attached.
Tesla Roadster 2nd gen 4680 Battery Anode at Giga Berlin 1633968153823
This all makes me wonder how similar the Cybertruck process is going to be.
Bitmaster
Oregon
Electrical Engineer
Isn't this going to make it impossible to replace the battery when it reaches EOL?
Ranulf
WI
Tri motor
No, as the structural battery is one of 3 parts put together to make the frame of the car. Even if it is welded, you can cut the welds and reweld it. The guys do it where I work all the time. Not a welder, so I don’t know any more details about how that works, but we use welds in our shot blasters (access doors are welded shut because bolts would just be destroyed by shot). We have to have the doors cut off and rewelded after we finish working on them.
if this is the “million mile battery” then operations like this will be few and far between. The family car (was my brothers, then my parents, now mine) is a 2007 with only 250,000 miles on it. And we drive far more than the average US driver. By the time you reach 1,000,000 miles you will probably have another car you want to buy.
(at 20,000 miles/year it would take 50 years to reach 1,000,000 miles)
Ogre
Dennis
Ogregon
Apparently they can drop the whole battery pack out the bottom of the car, seats and all.
Tesla Roadster 2nd gen 4680 Battery Anode at Giga Berlin 1633975498445
Thats how they assemble it, they put the seats on the pack first, then they slide it into the body. I assume you could do the reverse if you need to replace the battery.
TruckElectric
TruckElectric
Bryan
Dodge Ram diesel
The fact that the seats are connected directly to the battery pack freaked some people out on Twitter .........
FutureBoy
Reginald
Kirkland WA USA
Toyota Sienna
Financial Advisor
I thought Twitter people were generally just freaked out no matter what. Did this freakout rise to some other level high enough to break out of the twitterverse?
TruckElectric
TruckElectric
Bryan
Dodge Ram diesel
Not really.
