3D print mount for Uniden radar detector
gaubong053
Tuan
Sacramento, CA
MXP, Cybertruck AWD FS.
Software engineer
print came out well she does sag a bit but hoping the nylon is strong enough to not break and smash into my screen.
Seems like that nylon is not strong enough to bear the weight.
gaubong053
Tuan
Sacramento, CA
Software engineer
Here is mine when mounted with R8
Tesla Roadster 2nd gen 3D print mount for Uniden radar detector IMG_5677
gaubong053
Tuan
Sacramento, CA
Software engineer
Then you should try the latest with mentioned parameters. That will increase the strength of the mount.
Even more, you can increase infill density to 100% to create solid block to get the strongest of material but take more filament and time to print.
r0r0
Ro
Kansas City
Cybertruck Foundation Series 2024
Alright I will bite, I don't have a way to print PETG-CF, anyone able to print one for me?
gaubong053
Tuan
Sacramento, CA
Software engineer
Just PM your address, i will print it for you using pa6-cf. Btw, petg-cf is not suitable for high temperature environment.
bkandy3
Andy
Thousand Oaks, CA
AWD Cybertruck
I’ll post the Nylon 12 when I get it from Xometry to compare and see if it hangs, both immediately and over time.
May be a couple weeks because I’m waiting to get my Cybertruck back from service. Waiting on new wiper motor that was dead on arrival.
loki
localhost
pa6-cf is out of stock at the moment. When it’s back in stock I’ll get with the hardened nozzle. If/when the petg-cf fails I will retry with the pa6.
gaubong053
Tuan
Sacramento, CA
Software engineer
Actually, you don't need to buy it from Bambu store, just buy from Amazon(Polymaker makes good one) and select Bambu lab PAHT-CF profile. It works very well for me, just make sure dry filament before printing.
loki
localhost
PA6 it is! Would it make sense to also lengthen the mount and put more material at the bend?
Tesla Roadster 2nd gen 3D print mount for Uniden radar detector IMG_9819
gaubong053
Tuan
Sacramento, CA
Software engineer
Mine still works fine so i don’t think the bend is not strong enough. From your pic, looks like your layers don’t have good adhesion. Is it pa6-cf filament? Did you dry the filament before printing and anneal after that?
