espresso-drumbeat
Updates
Holy cow, one time charge limit. Thank the lord. I've been asking for that for years. Best practice is to charge to 100% only when you need it, so why there wasn't a way to charge to 100% only once, was baffling to me. Going into the app and trying to slide the slider to a charge limit is annoying to do. Every time I lift my finger, it moves.
- Security improvements
- Auto wipers
- View or reset tire mileage
- Rear passenger headphones
- Vehicle alarm includes trailer
- One-time charge limit
Same, seemed like a pretty obvious feature that should have existed 10 years ago.Holy cow, one time charge limit. Thank the lord. I've been asking for that for years. Best practice is to charge to 100% only when you need it, so why there wasn't a way to charge to 100% only once, was baffling to me. Going into the app and trying to slide the slider to a charge limit is annoying to do. Every time I lift my finger, it moves.
You can pick to have your car/truck charge up to 90/100%, just on that one charging session.Could you explain the one time charge feature a little more please?
What it should do is, remember your current charge limit, allow you to set a new charge limit that will only be reached once. then it will revert back to your original charge limit, without you having to open the app and manually set it back to that original limitCould you explain the one time charge feature a little more please?
Thanks!What it should do is, remember your current charge limit, allow you to set a new charge limit that will only be reached once. then it will revert back to your original charge limit, without you having to open the app and manually set it back to that original limit
Did you mean Auto wiper?
- Auto wipers
Are we sure this is not automatic? Have you tested this in the heat/beating sun?Damn!!!!!!!!!!!! No Cabin Overheat! c'mon Tesla!
ah, that is not optimal.The 125 degrees in my truck told me it definitely was not working. It's not even summer yet either!
