CappyJax
- Aug 2, 2020
- Bakersfield, Ca
- Subaru Forester
- Pilot
I see many companies using different speeds for range estimates. Those of you who own Teslas, what is the speed that gives you the advertised range? Does the vehicle change the expected distance remaining based on your speed? For example, if you are doing 70MPH, and you slow to 55MPH, does the vehicle instantly tell you what your remaining distance will be at the lower speed? If you have a destination set in the navigation system, will it also figure out expected usage based on climbs and descents?
