Tesla finally solves 4680 dry cathode process
Mini2nut
CT in 2026?
henchman24
Wyoming
Dual Motor Cybertruck
FWIW these cells have been in the CT since the fall. The Y is getting them in the 8L battery, which confirms they are slightly more than 26ah cells. Pretty large progress over the gen 1 Y 4680 that was about 23ah. A bit over the early Cyber cell that was tiny bit under 26ah (25.8-25.9ish).
henchman24
Wyoming
Same range as old cells?
There's no significant difference.... ~1%. Where manufacturing variation and any slight degradation make it essentially zero. LG (excluding newer M53 cell vehicles) and Panasonic pack 3/Ys have a larger variance between them (~3kWh).
I wonder if they still suck in the cold
All batteries suck in the cold, except for those Donut dry-electrode unicorns made of rainbows and unobtainum.
Outdoors
Outdoors
North West Montana
S,3,Y,C, Slate Res Hldr
Only thing worse than a cold soaked CT is a cold soaked Chevy Silverado EV.
I will say that smaller batteries tend to warm and use the amount quicker and charge faster. Big packs not so much.
Sposborn
Indiana
2024 Cybertruck AWD; 2025 Model Y Performance
Nope my model 3 was 10x better then cybertruck in the cold
I actually have been pretty happy with -15 wind chill days and my CT. My experience has been roughly the same between my 24’ awd cybertruck and all 3 of my past model 3s and my wife’s current 25’ MYP. What have you been seeing on yours?
henchman24
Wyoming
The 955 CT cells (early ones) are worse than the 3/Y cells in the cold. They don't really like to charge below freezing and at 5-10-15f there is a noticeable difference. You'll see the snowflake a lot more in those (any time pack is below 45-50f). The new cells are 973 chemistry which pushed the manganese up to a tad above 7% and the cobalt below three. Manganese in this style of cell is helps the thermal window and at that percentage, should get a lot closer to the current 3/Y cells... probably a bit short of that thermal window.
The 955 cells act like a midpoint between 811 cells and typical LFP chemistry in how they behave in the cold.
BlueLightning
Thomas
Oklahoma
Retired USA, Army
It was only to boost stocks…. 🥺 been five year, need another boost!
Tesla Roadster 2nd gen Tesla finally solves 4680 dry cathode process IMG_0604
Tesla Roadster 2nd gen Tesla finally solves 4680 dry cathode process IMG_0606
