Solved a rattle issue
BlazinB 704
Brian
Charlotte NC
CyberTruck, Model YP, C8
Got my Cybertruck on 11/19 and am totally impressed with it! One item I noticed while driving was there was a rattle coming from the front dashboard area, and rattles drive me crazy. After feeling around a little I noticed it was coming from the plastic around the steering yoke. If you feel around in the bottom there is a "tab" on the part closest to the truck not the wheel and it appeared to have some felt like material on it but could still rattle when going across bumps etc. I added another piece of felt from home depot to it and rattle so far is now gone. Just thought I would share in case others may have same issue.
Yup, I have a piece from a chip bag wedged in there for the same reason.
MyOtherTruck
Vermont
Can you add a pic? I may have same issue - sounds like sytrofoam from the steering column
MyOtherTruck
Vermont
Thank you for the photo! Appreciate the effort and helpful to see! My steering col sounds like a styrofoam cup rubbing against things!
CyberT
Orange County, CA
Service Technician
I just picked up a 49k VIN yesterday and put in a service ticket for the same thing. EVERY bump I heard a rattle sound from the driver door area. But maybe its what are describing. Ill check it out.
Cf400ex
Craig David
Phoenix,AZ
Model 3, Tahoe, Cybertruck
Real Estate
Thank you for sharing! Rattles are the worst.
Anyone have one on the driver door panel near the door speaker?
BillSirloin
Austin
Model 3
I have one near this area but it’s more of a tapping or rubbing noise. I think it’s coming from where the dash meets the side of the door but placed some felt in that area and its been gone for a week or so from what I can tell.
CyberT
Orange County, CA
Service Technician
That is precisely where my rattle sound comes from whenever I hit a bump in the road. Ill post a video here shortly
CyberT
Orange County, CA
Service Technician
Have the same issue? This may be the solution!
Thanks for finding a video, but that's not exactly what I hear. It sounds like it's more from the Woofer at the driver door.
Cf400ex
Craig David
Phoenix,AZ
Real Estate
Mine is also near the woofer in the door. I hear it with some music.
I did have the latch noise described in the video and service said the fix was grease in the latch. Wish I would have seen the video before I took it in.
While we are at it. How about a driver seat creak on the right side lower near the center console?
Sjohnson20
Cybertruck AWD, Model Y
I have a rattle that is constant at speed. Maybe around 40 mph or more. I only really notice when the music is low. Seems like it’s coming from the front of the dash but I can’t find it.
melb7425
Mel
cybertruck
Drove around with my audio off to hear the rattle from the dash on the left that I’ve been hearing. I noticed another that was coming from the right. Emptied my glove box completely, but still heard it. I sat in the passenger side and noticed a small panel near the mini window. I saw that it was hollow and seemed to be touching another piece of plastic. I’m going to try to put a piece of felt there to prevent any plastic rubbing.
