Software Update requests
SoFloCT
Matt
Model Y, Cybertruck Reservation RN 1135
1. Ability to see rear view on screen while having turn signal on. (shouldn't have to X out)
2. Small Bell button always displayed from navigation to turn on/off voice directions. (shouldn't have to press three buttons to get to this and I don't want to voice command it) maybe even auto turn off voice within a 10 mile range of home when home is destination
3. Vent from car option (not app) and automatically put windows up if it detects rain
bryantclan
Shaun
florida
Cybertruck, S, 3 and X.
1) Classic stay in your same lane Auto pilot while towing a trailer
2) better charging curve
3) variable regen levels like the Y so my wife is willing to drive the truck :)
4) An are you sure in the app before dropping the tail gate in the app.
Hazard One
Jeff
Boise, ID
Cybertruck, Model Y, Jeep Wrangler, Jeep CJ7
Retired USAF
I’d like to be able to use the nav system to navigate from a start point other than where the truck is for planning purposes…also would like to be able to do the same and not have the truck start conditioning the battery just because the nav system laid in a supercharger stop….maybe wait until the vehicle is in motion or a confirmation prompt before starting to condition. While I’m at it, you should be able to set a minimum charge amount for all stops, not just final destination
Absolutely agree with the last point. Adding arrival energy to multiple spots particularly on a long journey would give a lot of extra control
Partially Responsible
Robert
NJ
Accountant
I’m not sure if I am the only one who experiences this or perhaps I am the only psycho that’s driven nuts by it but I’d love to set my windshield wiper to an interval setting and NOT have it change on its own. If I set it to the first delay setting (not AUTO) it should remain on the first setting until I tell it otherwise. Currently it speeds up to setting 2 or 3 depending on its mood within minutes of me initializing. Oh and don’t get me started with the dry wipes with FSD enabled. Windshield wiper vent over…
Yeah. The wiper controls suck
Professor
Robert
NorCal
www.roberthawthorne.net
Cybertruck Foundation Series AWD, Ducati ST2
Theatre Technician
1) Have the ride height adjust when put in gear, not later. Currently it adjusts at some point in the parking lot. When backing up to a curb, it settles down behind the curb, and needs to be raised before moving forward, or it rips off the mudflaps. Also parking lots often have the steepest ramps. I scraped the battery recently getting out of one.
2) An option to set trailer lights to yellow and stay there. I have extra lights hooked to the trailer plug and every long stop it switches to blue. Blue removes parallel parking and changes FSD, so i have to manually change to yellow every time.
3) I'd like to get rid of the streaming option at bottom left of screen, sure i can swipe it away, but i shouldn't have to.
4) I agree with keeping the backup camera on, this isn't your average pickup, there is no rear view mirror. When using turn signals have the fender camera appear next to the rear view on the appropriate side. Shift over into the visualization if necessary.
5) In the visualization, have the CT be the color of the ambient lighting. I should be distinctive on the screen, not just like all those around me. It takes too many milliseconds to identify myself. The CT looks too much like a hatchback.
While the nav is speaking, you can use the scroll wheel to adjust the volume
Ed243
AZ
2025 Cybertruck AWD
What software update would you like to see for the truck? I would like to see being able to keep Wi-Fi off (it automatically turns on after 24 hours) and being able to use walk away door lock with the Apple Watch key. If anyone knows a way around these 2 things it would be greatly appreciated.
Couldn't you just "forget" the wifi network SSID?
Ed243
AZ
2025 Cybertruck AWD
I’m still wishing for a persistent onscreen button for the glovebox, instead of having to open the entire options screen which blocks navigation, etc.
You can set up a long press on the left scroll wheel to open and close glovebox.
Ed243
AZ
2025 Cybertruck AWD
Make UI consistent. Some windows use a swipe to dismiss while others require you press the little 'x' in the corner to dismiss.
jimbaum
jim
Plano, TX
Cybertruck, Model 3
You can stop it by turning it off and not use FSD. They aren't going to allow you to permanently disable when using FSD.
I just turn down my Amps so that it gets to the SoC in the AM to your liking.
