ajdelange
- A. J.
- Dec 8, 2019
- Virginia/Quebec
- Tesla X LR+, Lexus SUV, Toyota SR5, Toyota Landcruiser
- EE (Retired)
Yes, that's much better. No grammar school insults. And even better than that you actually did some thinking using MATH to come up with an estimate of how big the battery is AND beyond that you even recognize that uncertainty comes into it.The closest car in Teslas line to the CT3 is the Model X Performance. Gets 305 miles with a 100kWh battery. That's 3.05 miles per kWh.
Rivian with its range of 315 miles or so and a 135kWh battery sits at about 2.33 miles/ kWh.
Your 500 mile/ 220 kWh battery is 2.27 miles/ kWh. Thats less efficient than the Rivian. I suspect even the tri motor Cybertruck is going to be lighter and more aerodynamic than the Rivian.
If the Cybertruck splits the difference it would be at about 2.69 miles/ kWh. That would be 190kWh for the tri. The Dual would be about 120kWh.
I'm not suggesting that's what it will be, that's definitely optimistic. Likely it'll be more than that, but 220kWh is about as likely as 160kWh.
Notice... you can make a point, make a post readable, and do so without insulting anyone.
Looking at the MXP with its consumption of 328 Wh/mi, the MXLR+ with its consumption of 282, and the Rivians with theirs of 433 is certainly a reasonable thing to do. But why stop there? There is more information available. ABRP thinks the CT consumption will be 412 and that the Rivians would come in at 432. They came pretty darn close!
I don't have a 500 mile/220 kWh battery. Based on the vehicles we're comparing I'm estimating the consumption at 420 Wh/mi. Note that this is bit conservative relative to ABRP's estimate but still a little less than the RIvian's. We know Rivian's curb weight is 5886 lbs and its GVW 8500. The CT's curb weigh estimates range from 5000 to 6486 lbs and with 3500 lbs payloads GVW would fall between 8487 and 9986 lbs. So we can't grant the CT much advantage for weight. Where it will probably do better is in the drag department.Your 500 mile/ 220 kWh battery is 2.27 miles/ kWh. Thats less efficient than the Rivian. I suspect even the tri motor Cybertruck is going to be lighter and more aerodynamic than the Rivian.
Anyway that give 500*420 = 210 kWh as my estimate for the battery size based on comparison to other vehicles and ABRP's estimated conumption for the CT.
The next logical step is to see if we can figure out what some of the individual loads are. We know the dimensions of the CT and Musk has put 0.30 out as the holy grail for its drag coefficient. That quicly gets us 168 Wh/mi for the drag load at 60 mph. Likewize assuming the middle of the weight estimate gives us 114 Wh/mi for the rolling resistance load. Assuming 90% drive train efficiency slip of 0.1 and 50 Wh/mi for the inertial load (a WAG) we'd have total comsumption of (168 + 114 + 50)/.81 = 410 Wh/mi.
Now in an adult conversation someone who didn't think 210 is a reasonable estimate would be able to say things like "Hey not so fast! What did you use for a rolling resistance coefficient?" and they say why he thought the value I used (0.01) was unreasonable. Those here who understand something about engineering (and there are several) also understand that an estimate is an estimate subject to uncertainty. Every number in that formula is subject to some uncertainty. Just to make things simple I assumed 10 Wh/mi uncertainty on each of the drag, rolling and inertial loads and an uncertainty of 2% on slip and drive train efficiencies. The following picture shows probable battery sizes based on the loads I calculated and the uncertainties I assigned.
I know this picture will be meaningless to some here but I also know there are some here who understand exactly what it is saying and that is that the pack size will most probably wind up between 185 and 220 kWh, most likely a bit less than 210.
