Problems With Installing New Lock Chime Sound
UnRich1
Rich
Boise ID.
TriMotor CyberTruck ordered , Kia Teluride, D1500
Retired Diplomat
I following the instructions, loading it in the root directory and naming it “lockchime.wav” . And it is a good wav file. What am I missing? Is anyone else having a problem doing this?
UnRich1
UnRich1
Rich
Boise ID.
Retired Diplomat
LockChime.wav *caps
And
less than 1mb?
I’ve tried it both ways, with caps, and without caps. Yes, under one megabyte.
JUSTICEQD
Benjamin
Johns Creek, GA
Doer of IT stuff
Was the file an actual .wav or did you just rename from another format?
UnRich1
UnRich1
Rich
Boise ID.
Retired Diplomat
Kryptek
Alaska
Cybertruck AWD Gray Interior VIN 4xxxx
Try another wav file perhaps or got corrupted or is using a codec or compression or hz quality not compatible
UnRich1
UnRich1
Rich
Boise ID.
Retired Diplomat
I have done, and some from this site. I’m relatively tech savvy but this is puzzling.
Kryptek
Alaska
None work?
I have not taken delivery yet otherwise I’d try to help more
Are there multiple partitions? It technically shouldn't matter which partition gets the file, but I've only tried the "MUSIC" partition. I posted my partitioning instructions here.
The only other thing I can think of is the two-thumbed salute (hold both scroll wheels until the screen reboots).
UnRich1
UnRich1
Rich
Boise ID.
Retired Diplomat
My thumbnail drive is not partitioned at all. I’ll set up the partitions and see if that solves the problem.
Bobo_LaDouche
Carson City, Nevada
Cybertruck, Model 3
Let me know if you find a solution. I have the same problem. It should be easy to add a file; this is perplexing to have to resort to trial-and-error approaches.
UnRich1
UnRich1
Rich
Boise ID.
Retired Diplomat
Well, it worked after erasing the thumbnail drive, and reforming it to fat32 but now the dash cam and security files don’t know where to go. I think if I make some directory files for them, that will fix it. I was not able to partition the Tesla thumbnail drive. I don’t know why, but it will not allow it. If anyone knows of a good workaround, please let me know.
Gaximus
Mead, CO
Software Developer
Did you format using the CyberTruck to format?
