Phone won't connect using BlueTooth
Jhodgesatmb
Jack
San Francisco Bay area
www.arbor-studios.com
Retired AI researcher
I have been wandering through the settings on the Cybertruck and thought I'd try to play music and/or call on the phone and I cannot connect using Bluetooth. I turned Bluetooth off and on again with no luck. The truck can see the phone but will not connect. There is no issue with seeing the phone on wifi. Has anyone experienced anything like this? Thanks!
mark555055c
Buffalo, NY
I've not had any issue. I connected three android phones to my CT and all work great with music, phone key, etc.
getsometom
Tom
I have a similar issue however my phone is connected via blutooth. Spotify and phone calls work however any other audio coming from my phone isn't broadcasted into the truck. For example, audio from my phone's YouTube App. I also have the truck identified as car stereo on my iPhone 15 Pro.
How many phones are connected?
Did you try hitting connect from the vehicle's Bluetooth screen?
KrennPowerSports
john
DFW,Texas
none yet.
my new truck mic doesn't work nor does it connect iphone to speakers. It says it's connected, I can call out but i hear nothing and people on the other end hear nothing. Check your voice commands also, i bet that doesn't work. it's like the system isn't connecting the "sound" on the mic and the speakers.
I know that this sounds stupid, but have you adjusted the volume when in a call?
To hear music, you have to switch the audio source to Bluetooth, It's a common problem that you start to play music on the phone and you don't hear anything. The phone says it's connected and the vehicle says it's connected. It's just that the vehicle's audio selector has not been switched to the phone.
igs
CT, MX, MY
I connected my new phone to the Bluetooth, if I recall it was being weird and it took several tries.
Are you able to make subsequent connections without several tries?
TexasRaider
JR
Denton
Cybertruck + MS
Civil
Ditto here.
I was talking on my phone through the CT while charging. Then opened to the door to disengage the SC and when I got back into the driver seat I saw that my call was transferred back to my phone. And I had to manually re-connect my phone to Bluetooth to finish my call on the way home.
