Odd Cybertruck noises?
megalodon
SoMD
MY, CT
CT AWD. Anyone hear a beep/chriping noise who's fequecy is dependent on speed? Over 40mph or so it goes away, (probably too high a frequency for me to hear) but comes back at lower speeds. It seems to be getting less noisy as I add miles. The CT drivetrain is much noisier than my MY.
At mid height shock level, it sounds like the truck is pressurizing the air shocks every 2 or so minutes. Is this normal? Sounds like a whooshing noise from the right rear.
I've also go an intermittent rattle under the left front dash.
Thanks for your input.
RDMSguy
Los Angeles, CA
2024 Founders Edition Cybertruck
Yes. This is normal.
This doesn't happen to mine. I have only ever heard the compressor running maybe a handful of times in 18k miles. If your talking more about the air bleeding (whooshing sound), then I hear that whenever the suspension is lowering (IE sometimes when picking up speed on the highway, the truck lowering down the height for the higher speeds, etc). But its not definitely not every couple minutes.. More like a couple times per long distance drive for me.
As with my 24 Model 3, my Cybertruck included a bunch of annoying rattles I spent weeks chasing and mostly silencing.
koolio
Greater Boston, MA
Wild guess but could it be a speed limit warning? Like someone accidentally set the speed limit warning to 40mph (or whatever speed you’re hearing the chirp)?
megalodon
SoMD
MY, CT
see if you can get clean audio. CT motors do make a distinct chirping noise.
If the chirp/beeping noise that increases frequency as speed increases, I guess I'm OK. It was really loud when I picked it put but after 4k miles it is getting quieter. My MY does not make this annoying noise. I'll attempt to get a audio recording. Love the CT regardless. I just towed a 30 ft boat trailer w/ no issues.
