- Roger
- May 13, 2024
- Poway, CA
- Cybertruck
- Occupation
- manufacturing
Happy Hump Day Cyber crew!
Just wanted to drop the release of our new Universal Light Mounting Bracket Kits to easily allow you to choose your favorite light brand, our is Baja Designs, or whatever fits your budget - plenty of sub $100 options on Amazon these days.
Our Universal Top Light Mounting Bracket Kits are designed to work with any 48-52" light bar of your choosing to upgrade your off-road lighting. They are made with 14 gauge stainless steel (same as the Cybertruck Body panels) with a matte black powder coat to endure the test of time, no rust happening here!
Easy to install, remove the 2 top plastic covers, and install using the supplied locknuts. Then mount your light, wiring and you’re off to a night run with more light to guide you on the trail.
Easy to install, remove the 2 rubber recovery hitch covers, and install using the supplied hardware. Then mount your light, wiring and you’re done.
- Compatible with any 48-52″ light bar – From Baja Designs to Amazon
- Included 48V Step Down Converter Simplifies installation
- Easy-to-use quick disconnect plugs make removal easy
- Stainless Steel with a matte black powder coat finish
- Compatible with many fog lights and ditch lights
- Compatible with up to 38″ light bar
