Ken in Miami
- Ken
- Aug 29, 2024
- Miami, Fl.
- 2024 Foundation series
- Occupation
- Real Estate/ Agriculture
Great idea. ThanksThe TC-BL gets hot when filling only one tire at a time (if you don't turn it down to 50% speed) because it flows so much more air than a Schrader valve is capable of flowing. That's why I recommend filling all tires simultaneously with 4-way hose, or turning the compressor down to 50% power if filling one tire at a time.
What happens is the pressure between the inflator and the tire valve rises to a very high pressure, even if your tire is completely deflated or has very low pressure in it. That means the compressor is doing far more work than is actually being accomplished (due to the restriction in the Schrader tire valve).
Rather than an electrical extension cord that might cause your inflator to get hotter than necessary, you want an extension air hose so the compressor can remain on the tailgate.
