TruckElectric
- Bryan
- Jun 16, 2020
- Texas
- Dodge Ram diesel
- Retired
10GWh is only 100,000 100kWh battery packs.My 7 big takeaways from the meeting:
* Cell Production of the 4680 is finally on track with 10GB production in Fremont.
The 10GW production is destined for the Model Y. It is 150,000 - 160,000 Model Ys.10GWh is only 100,000 100kWh battery packs.
What does that mean for CT production?
Probably not as much as we want. I'm expecting my 42k position will be lucky to happen early 2023, given MY will take the first batches of 4680s, maybe even all of the 10GWh according to EM today.
Me be sad... :‐(
I'm going through this modeling right now. We're building a new house, and are doing everything we can to make it low-consumption all-electric. Well insulated, ductless minisplits air-source heat pump, hybrid water heater, etc. R-32 walls, R-50 ceiling, in Michigan. And it doesn't matter what more I put in the house - the ~70kWh/day my 2 EVs will pull down dwarfs the household consumption by a LOT.Interesting that EM said a doubling of household power consumption if the household has two cars, and a trebling if house heating is added.
We have some work cutout.
The other more cost effective way to do it without powerwalls is to buy a extra CT so you can alternate between using cars and leave the other at home to charge during the day. The price of 70kWh of Powerwalls will get you a DM CT. Otherwise if you wanted to keep one as a weekend vehicle and the other as a commute vehicle, you can just plug in one CT to the other (that charges from solar at home) via the powerpoints in the bed to charge it overnight with about 8-10kW.So if I want to charge off solar, I don't just need a huge array (which I'm fine with) but I need 70kWh of backup battery to draw from just for vehicles. And if they charge most every day (lets say 300/year), that 1,500 charge cycle life expectancy on a Powerwall is only 5 years long.
Yeah, we're going with a double-wall with a break to reduce thermal barriers, and focusing extra cash on good windows/doors. Due to the nature of the house we have to have an air exchanger - but we haven't considered any sort of heat recovery unit. I'll have to look into those.The other more cost effective way to do it without powerwalls is to buy a extra CT so you can alternate between using cars and leave the other at home to charge during the day. The price of 70kWh of Powerwalls will get you a DM CT. Otherwise if you wanted to keep one as a weekend vehicle and the other as a commute vehicle, you can just plug in one CT to the other (that charges from solar at home) via the powerpoints in the bed to charge it overnight with about 8-10kW.
Either way CT is a cheaper and better value option than powerwalls. That's why I have 4x on order.
There's also some PV to vehicle chargers out there that don't need batteries, that make the above even more affordable. The trick is to be able to modulate the EV charge rate according to the current solar power availability.
BTW well done on the insulation of your house. Remember that heat transfer occurs through three main methods; conduction, convection and radiation. If you haven't already, have a look at heat recovery ventilation systems to keep your convection losses down and roller shutters on your windows for radiation losses in winter and gains in summer.
So you guys don't have net metering? During the day while you're away, your solar system could bank your energy for overnight.Yeah, we're going with a double-wall with a break to reduce thermal barriers, and focusing extra cash on good windows/doors. Due to the nature of the house we have to have an air exchanger - but we haven't considered any sort of heat recovery unit. I'll have to look into those.
I'm really hoping that battery costs come down significantly in the next few years. If we move in late next year, then hold on solar install for another 6 months or so to get accurate Winter consumption numbers, then go with a SolArk or other hybrid inverter I can scale battery backup as money allows and prices change.
The additional vehicle thing becomes a bit of a problem in MI where even "cheap insurance" is expensive - and a third EV that just gets rotated will cost me likely $2k+/year to just sit in the driveway. The money math might work, but I haven't busted out my spreadsheet yet.
Funny how people say California's F'd up. There's always many ways to look at any situation.Michigan utilities won a "maximum number of customers on net metering" quota a while back, and they've hit that quota. I'm in DTE's territory, and new solar installs are not net metered - they're governed by a pain in the butt credit system that gives you credits for off-peak even if you're producing on-peak, but you also still get charged for transmission of your own power back into the grid when you produce in excess.
