Nidavellir
You should paint your calipers while you’re at it.
This works well
This works well
I posted the same idea last month. Post #20.AH HA!!! I finally got the truck higher enough to rotate the tires. BARELY high enough but it worked. I need to have the exact amount of wood under the jacks and rotate the screw higher so it touches the truck. Then jack it up and managed to get enough to remove the tires and switch front to back and back to front. Now to do the passenger side.
That's what I did again but I had better wood and snugged the screw adjustment ALL the way up and reduced the space to nothing! I don't think it would work on grass or soft dirt.
T-Sportline has this one listed, but mentions you have to have the stock CTX bumpers, the stock bumpers won’t work. Doesn’t sound like high lift jacks will work with the underbody jacking points, need aftermarket bumpers for this style of jack.Serious question: Would a 7000-lb capacity farm jack work? Hi-Lift jack
18" Height limit versus Tesla 21", not sure if it is tall enough when fully extended?See warnings.
I just saw the Artic Cyber Trek video and noticed they were carrying a Hi-Lift Jack, has anyone tried using one on the jack points of the CT? Here’s a screen grab from the video with the jack mounted to the exterior molle panel.Serious question: Would a 7000-lb capacity farm jack work? Hi-Lift jack
I would think that should be fine as long as you angle it so you are putting pressure on the edge of the pack. Those Hi-Lifts are not light though (but they do work extremely well).I just saw the Artic Cyber Trek video and noticed they were carrying a Hi-Lift Jack, has anyone tried using one on the jack points of the CT? Here’s a screen grab from the video with the jack mounted to the exterior molle panel.
I think that is for show. It would not be able to grab the jack points, they are too far in and the angle is extreme. They might be able to use it on the hitch or hooks in the front...?I just saw the Artic Cyber Trek video and noticed they were carrying a Hi-Lift Jack, has anyone tried using one on the jack points of the CT? Here’s a screen grab from the video with the jack mounted to the exterior molle panel.
Did it work?I bought the Big Red bottle jack 12 Ton. I’ll let you guys know how it performs.
They would need to have jack stands or something else to set the CT on if they used the first option to jack up the CT, but that is possible.
