Hauling a fridge in cold temps…beware!
Foo$fun
Ro
Soon to be Seattle
Cybertruck & Model X
Engineeri
1. Why didn’t you lay the fridge down?
2. What do these stickers say?
Pitt to Det didn’t think it was short distance- it was a 6 hr drive and didn’t want to risk any leaks
Outdoors
Outdoors
North West Montana
S,3,Y,C, Slate Res Hldr
So back to the fridge. Those things that contain refrigerant need to be stored upright or in original usage condition. The oil in the compressor will move around and make it not a good sit. One could lay it on the side, and wait some time, but the problem might be the bed length.
Foo$fun
Ro
Soon to be Seattle
Engineeri
Come on folks, quit reacting to this.. we've seen this plenty of times on here.
As a newbie what are you referring to? Yes I joined very recently but definitely appreciate many of the posts here and just wanted to share. Enjoy and Happy New Year!
ChiTownCT
CT
Chicago
CYBERTRUCK
I just hauled a commercial fridge, laid it on its side entire time.. Let it sit for 48 hrs upright before I turned it on.. No problems
Outdoors
Outdoors
North West Montana
Ok did it fit the bed of the CT? Here I don't think it does. One can't lay it on the area behind the glass roof without wrecking the rolling mechanism. Kudos for you and your moving. Most buy a fridge at home depot. I know mine (built in) would never fit in the bed any other way other than upright.
ChiTownCT
CT
Chicago
CYBERTRUCK
54x32x82 high fit on its side with tailgate open no problem. Strapped it and hauled it for about 70 miles.. Now I wish I took a picture and bragged about a truck doing truck things in the other thread :D
Tesla Cybertruck Hauling a fridge in cold temps…beware! Screenshot_20260101_181001_Brav
MSL2
Mike
PA, USA
Y, Cybertruck, EV9
Yeah, the rule of thumb that I always heard was that it needs to be stood up for twice as long as it was laying down before plugging it back in. I'd still rather not lay it down if I could help it to avoid the risk. But that's just me.
Tallgeese179
Nikola
Pittsburgh, PA
2025 CT AWD, 21 BMW X7, 15 370Z Nismo
Shout out from the Burg! The PSA is appreciated, I discovered the same info but on YouTube:
As others have mentioned, weight makes negligible impact but the aero hit is tremendous. The tarp and ratchet straps make it even worse. I understand it's unavoidable in this situation, so just add a buffer like you said and you'll be fine.
Personally I don't understand the whining about "range sucks = this truck sucks". Hell even Achilles had a friggin weak spot. I could go around all day shitting on other trucks (and would gladly do so) for riding like an ox cart, turning like an aircraft carrier, being slow as hell, having a 4 ft bed, not being able to drive itself (for the most part), not having 240V power, yada yada yada
The solution to range is stopping and charging. Even if it's every two hours, 30 mins flies by. Long distance hauling isn't its strong point, but hell it does stuff nothing else can. Can't have it all 🤷‍♂️
Cold reduces range. Drag reduces range. This is non-controversial.
The longtime lurkers/posters here have read about such effects many times.
If your current efficiency is insufficient to reach a charger, slow down. Drag increases exponentially with speed. Disabling climate will save a few Wh in a pinch.
BlueLightning
Thomas
Oklahoma
Retired USA, Army
Yes, there are thousands of examples where the CT has beat the odds doing real truck stuff.
Agreed, any EV don’t like the cold.
But in the end this is what the CT was most likely intended for daily…
Tesla Cybertruck Hauling a fridge in cold temps…beware! IMG_0031
Foo$fun
Ro
Soon to be Seattle
Engineeri
right but that was only 70 miles - not over 200 miles - it’s ok to lay down for short distances but we hauled for over 200 miles and we didn’t have 48 hrs to wait and then plug back in…we chose the best option we thought that would be the safest, quickest, and most inexpensive option given the circumstances and constraints we were up against.
Cybergirl
Illinois and Arizona
I carry a CCS to NACS adapter. If I can't get to a Supercharger before the battery is completely drained, I often have the option of charging at a non-Tesla charger. Warning: It can be a frustrating experience if you haven't done it before.
