Door will not open from outside
TARSinDE
Glenn
Delaware
Cybertuck
Driver side rear door will not open. The white light in the middle of the button is not lighting up, nothing happens when pressing it. The door opens fine from the inside.
Spoke to support, they think it’s a firmware issue so I’m without a functioning door for a few weeks. Thank god it’s not the drivers door.
Anyone else experiencing this?
MyFirstElectricTesla
SoCal
Benz
Can you open from app?
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
Retired truck driver
if the light is not lite, I am thinking the plug is disconnected. But then again, I don't know what I am talking about.
Oh, that's certainly a possibility. A loose connection can give incorrect diagnostic data as well.
It could also just be broken. Random parts do fail, and it sucks when it's just yours.
If it's a software issue, they might be able to tell if there's a firmware version or touch date difference when they access the service interface. Like the radio for the key cards, updating the distributed processing units can fail.
I’m gonna show how dumb I am. I have no idea to do that. I looked at the app and I can only see how to open/close the trunk and frunk.
The feature was only recently added. You must be within close range.
Gaximus
Mead, CO
Software Developer
In the app Select Controls. Brings you to a screen where you can control most things, bed cover, charge port, doors(if in range) horn, windows , flash lights. Try that. Also check if the button on the inside of the door opens it. If so the outside button is either disconnected or broke.
KG206
Kevin
Maple Valley, WA
Dual motor
Wouldn’t service have recommended bringing it in to replace/repair, if they thought it was a disconnected wire or broken?
If they don’t even want it brought in, it’s probably already a known issue at this point.
guppus
Nassau County
Just curious, did you add aftermarket puddle lights….the ones that project an image on the ground when the door is open?
Gaximus
Mead, CO
Software Developer
They could be misinterpreting the problem with “door not opening” or their diagnosis tool is reporting back that the button is faulty and he has to bring it in anyway. We are just trying to diagnose it more for our own edification.
