Brandon McNees
- Brandon
- Jan 12, 2025
- Grand Rapids, MI
- Tesla Foundarion Cyberbeast
- Self Employed
Thanks!Lynwood,WA that was from September 24
Post pictures after the service is complete please! Thanks for sharing!I finally had a tech at the service center agree it needs to be fixed. He stuck his pinky in the roof where it rolls up and said yes there's too much space and they have a part to order that repairs the leak. Funny it took 3 trips complaining 3 times for someone to agree. This time I really complained because my storage area was full of water because I didn't pull the plug and said it should not fill with water.
Do you have any more info on this rubber seal for the top on the tonneau outside of the article in the link you provided?
Did you caulk the top (outside) or inside the vault?The holes everyone is showing is not the cause of the leaks (at least in my experience). The URL reference posted above by docowen is a good source for where the leaks occur, and in that video you will see a very poor seal being replaced by rubber. My truck is a later version, with a rubber seal already upgraded as OEM from Tesla. However, my rubber seal also leaked, and when I removed the cover (and two bolts to do so), the rubber gasket was compromised by an irregular pattern in the metal border (see pic below) and that was my cause of leak on both ends of the metal piece I removed.
I put everything back together and used a silicone Permatex sealant to run a "caulk" bead down the gulley and that fixed my leaking Tonneau.
https://www.amazon.com/dp/B000AL6WLA?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
BTW, my Tonneau cover has exactly the same border holes as shown in other thread responses. On appearance it looks like that might be the culpret but it my case it was not.
I would post a picture of my solution, but Helene dropped a tree from our front yard onto my 1-month old truck, shattered the windsheild and now I am without my beloved beast waiting on parts and fix, driving instead a camry rental. I did authorize my Hermes PsychoPomp (my truck name) to download and install the FSD upgrade, from 40 miles away while it sits in service parking lot, but am unable to use it. Anticipatory joy awaits, probably will be 4 weeks before I'm back in drivers seat.
This one was too thick for me. I couldn't close the cover and line up the holes. I think every car is different, just gotta try and see which one works!FWIW,
I removed the factory seal due to a poor initial install from the factory & replaced it with this Amazon.com: M-D Building Products 01033 10 ft. Black Large Rubber Auto & Marine Weatherseal for All Climates, & so far have a dry vault (knock on wood).
