rjmcinnis
- Jason
- Sep 22, 2025
- Florida
- 2024 Cyberbeast, 2018 M3P
- Occupation
- Cybersecurity
Would love to get SPAN, but would need two of them with my 2x200a service. Wish they had offered it at build time, but unfortunately while they are a good builder, they are just not enough of a tech forward builder.They're supposed to be installing a SPAN IO panel today and I look forward to being able to see more about what's using what in the house.
My heat pump, water heater and heat pump HVAC both appear to use about 500 w or so when they're actively running. When the HVAC's not running the heat pump it's still running a fan but I've not really been able to detect that running. The old HVAC without a heat pump. I'm sure drew a lot more power when it kicked on 5 or 10 minutes every hour.
How small is your HVAC? Or what efficiency? My 5-ton Heat Pump uses ~3500w, but it's a 15.5 SEER. I wanted to upgrade to a higher SEER (specifically for the variable fan) , but it was considered a "structural option" and had already been approved/permitted prior to close, so couldn't change it.
