dw321
- Jun 10, 2023
- Arizona
- Ram 2500, Toytota 4 Runner, Bikonit Ebike
I asked GROK the following:
I have two E-bikes that weigh 90 pounds each. The bike carrier weighs 45 pounds. Can I carry these bikes on the cybertruck hitch
Answer
Given the information provided:
According to Tesla's lead Cybertruck engineer, Wes Morrill's clarification:
I then asked:
how many cybertruck hitches have failed
Answer
The precise number of Cybertruck hitch failures isn't directly provided in the information available up to November 1, 2024. However, several instances and discussions around the Cybertruck's hitch reliability have been noted:
Answer
- Each E-bike weighs 90 lbs.
- The bike carrier weighs 45 lbs.
- Total weight of both e-bikes: 90 lbs. * 2 = 180 lbs.
- Weight of the bike carrier: 45 lbs.
- The initial vertical load limit of 160 lbs. was under scrutiny for being too conservative or potentially misinterpreted.
- For non-towing applications like bike carriers, where the load's center of mass might be closer to the hitch, the vertical load can be significantly higher. Specifically, for a motorcycle carrier, a figure of 375 lbs was mentioned.
- If the e-bikes and carrier setup's center of mass is considered similar to a motorcycle carrier setup (where the load is relatively close to the hitch), you might fall within the adjusted vertical load limit of 375 lbs.
- Safety First: Even though the Cybertruck's hitch might technically handle the weight, exceeding any specified limits could risk damage to the vehicle or the hitch over time due to stress or unexpected loads (like hitting a pothole).
- Tesla's Recommendations: Always refer to the latest guidelines or any updated information from Tesla regarding load limits for specific configurations. If Tesla officially states a limit for such a setup, that should be your primary reference.
- Dynamic Load: Remember, static load (like what you're calculating) might differ from dynamic load when the vehicle is moving, especially on rough roads or highways.
- If the bike carrier setup's center of mass is comparable to that of a motorcycle carrier (which isn't guaranteed), and if you're comfortable with potentially pushing the limits set by Tesla for non-towing applications, you might technically carry your setup.
- However, for safety and warranty considerations, it would be wise to contact Tesla or refer to any updated documentation to confirm if the 225 lbs total setup weight is within the recommended or allowable limits for your specific configuration.
- If there's any doubt, it might be prudent to look into alternative mounting solutions or lighter equipment to stay safely within specified limits.
I then asked:
Answer
- There have been documented cases where the Cybertruck's hitch or rear structure experienced failure under extreme conditions, like in a "torture test" where forces well beyond normal usage were applied.
- Social media, particularly X (formerly Twitter), has seen posts and discussions where users have shared or discussed instances of the Cybertruck hitch either failing or being significantly weaker than expected for vertical loads, leading to concerns about its towing capacity in real-world scenarios.
- Tesla itself addressed the confusion around the hitch's vertical load rating, clarifying that while the tow rating is 11,000 lbs, the vertical load rating varies significantly based on how load distribution and the type of accessory used, with a maximum of 1,100 lbs when directly towing a trailer, but much less for extended accessories like bike racks.
- No specific number for total hitch failures across all Cybertrucks has been provided or is commonly cited in general knowledge or the snippets from X posts or articles up to the last update.
- Public instances and discussions suggest there have been multiple failures or concerns raised, but these are anecdotal or from extreme testing scenarios rather than everyday use statistics.
- Tesla's clarification on the hitch's use indicates that while the design allows for high towing capacity, misuse or misunderstanding of how to apply loads to the hitch can lead to failures or perceived failures.
