Cybertruck engineers bend upper control arm in testing
Gurule92
Colorado Springs
MYP
"Cyber" stuff
Plenty of time before real customers get theirs.
Gurule92
Colorado Springs
MYP
"Cyber" stuff
The upper is not bent, IMO, simply a different viewing angle causing it to appear that way. You would have to ask yourself, what would have impacted it to cause it to bend upward? Other components would have needed to fail before the upper control arm could have been pushed upwards by an outside force. Launching the vehicle in Baja would not have done this either, as this is a pivot point for the upper ball joint. Rather, the strut tower would have likely blown out, or the chassis control arm mounts would have ripped. I'm leaving it at that...
Possibly a big rock got kicked up?
SolarWizard
MB
San Diego//Tampa//South Park, CO
3.0L JT // Quad CT
solar, DCFC & battery biz owner
It’s absolutely bent. Don’t focus on the arm. The Ball Joint is destroyed.
cvalue13
F150L
Fun-employed
Those pictures aren't from the same angle so they won't line up like you are showing. You can't even see the label in the top image.
the picture isn’t intended to show the angle of the yellow line, though
it’s intended to show the departure from the yellow line, and the angles of other pieces relative to it
maybe it’s better displayed this way, here with these red lines all being erfectly parallel:
Tesla Roadster 2nd gen Cybertruck engineers bend upper control arm in testing DF51C298-A714-4033-967E-5E237C6C37F0
in contrast:
Tesla Roadster 2nd gen Cybertruck engineers bend upper control arm in testing 6B45D1E8-BA24-4F5C-8CC1-F2E33AD206C0
SpaceYooper
Colorado Springs
13' F150, 17' Explorer, 13' Cruz, 13' Clubman
Retired USSF SNCO, REALTOR®
Regardless of what damage was done, the UCA doesn't look like it would hold up well at all.
I replaced the UCAs on my truck when I went to 35" tires. I would hope the CT used forged or tubular UCAs in production. Like others here, I'm surprised they even tried this.
scottf200
Western NC
X; immed family 3 & Y
@cvalue13 did a nice job with the pictures and lines.
Just look closely at the rubber protector and you can see it is deformed/compressed pretty differently.
Hard to believe people are defending this at this stage of development.
Tesla Roadster 2nd gen Cybertruck engineers bend upper control arm in testing 1flOvLI
Yes, the two photos are at different angles, so no, I don't see how it's deformed.
The lines of the lower bulb (in the supposed upper image) are parallel. They wouldn't be if the arm was bent.
Mini2nut
Mini2nut
CT in 2026?
I think it's clear that Tesla's goal was weight savings and low manufacturing costs. Even the rear lower control arms are steel.
Beefier aftermarket upper control arms are very popular in the off-road community. Plenty of vendors manufacture stronger arms.
Toyota tackled this problem by offering forged upper control arms as standard equipment on their Tacoma TRD Pro. They even come painted red from the factory. This 2022 change severely crippled the aftermarket upper control market for the TRD Pro model.
https://twstatic.net/attachments/2022-toyota-tacoma-trd-pro-005-jpg-jpg.4638567/
scottf200
Western NC
Mini2nut
Mini2nut
CT in 2026?
Great close up’s. You can see the difference in the upper ball joint rubber boot.
The Cybertruck would have to encounter one hell of an impact to bend an upper control arm.
Tesla Roadster 2nd gen Cybertruck engineers bend upper control arm in testing 1698272485523
Tesla Roadster 2nd gen Cybertruck engineers bend upper control arm in testing 1698272534028
Curious. To me one looks compressed and one looks opened up.
Yeah, but do you see the difference in photo angle? Look at the wider shot and the distance between the arm and the well cowling in the two images.
Boycott Tesla! Ok yes, yes they must have really bottomed out hard?! Not! If it’s cheap pressed steel at least spend a little more $$ for better quality! Junk, the CT A arm isn’t even double pressed steal it’s one single?! But it’s what you like! Kool Aid drinkers enjoy!
So we'll halve the thickness of the steel, then rivit them together, and then totes it'll be better 'cause it's twin ply, right?
Can you show the line that's supposed to have bent?
'Cause I'm not seeing it. Is the bottom one normal?
I was going to ask this yesterday already:
You really can't see how it's bent up on the end?
Robesaw
Vancouver
Cybertruck Dodge Ram
Sales
I’m shocked they even tried to offer a stamped steal upper control arm. The balljoint size looks a little suspect too.
“Kicking butt in baja” is gonna require the aftermarket 100%
I agree. I wonder if this was required for wheel tear away in crashes?
