Coolant fluid top-off?
Beetlebug62
Ken
Maine, USA
2018 Tesla Model 3 LR-AWD, 2025 CyberTruck dual-motor
So, I'm at 4700 miles, and I recently pulled off the covers in the frunk to thread some wiring, and noticed my coolant fill tank was empty. I've noticed no leakage. And there does not seem to be any error codes in the service menu. No issues whatsoever.
Tesla Roadster 2nd gen Coolant fluid top-off? IMG_0678
My service center is 2 ½hrs away, and I was wondering if I should just top up the coolant, myself, rather than have to make a big trip. Looking at the manual:
Tesla Roadster 2nd gen Coolant fluid top-off? by default 2025-11-07 at 9.47.55 AM
I've never given coolant much thought, but it looks like they're color-coded, and that HTF-LS is orange, and is OAT, ie Organic Acid Tech. The three main brands, Prestone, Zerex and Peak all sell an orange OAT coolant, but none have any HTF-LS markings. Can I use it?
Anyone know?
Oh, I've never looked at the coolant tank before, so I have no idea if the truck came like that or not. But, as I mentioned, there does not seem to be any leaking or error codes. Should I top up, and keep an eye on it, and if it drops, schedule a service?
Cyber AI
Asim
Gainesville
CyberTruck AWD, 23 Model Y Long Range
Senior Graphic Designer
You shouldn't have an empty coolant tank. There must be a leak (or not properly filled at the assembly). I would have it check with SS.
Beetlebug62
Beetlebug62
Ken
Maine, USA
And I did look in the Tesla parts catalog:
Tesla Roadster 2nd gen Coolant fluid top-off? IMG_0806
and it says "not sold by Tesla, order from 3rd party, and shows a bottle of Zerex. Obviously that's the blue G48 version.
Tesla Roadster 2nd gen Coolant fluid top-off? IMG_0814
and when you punch in the part number, you do get the orange HTF-LS version, but like the previous image, it says the same thing to order from 3rd party.
The only other thing I did was to look in the service menu at the coolant loop for possible errors:
Tesla Roadster 2nd gen Coolant fluid top-off? IMG_0808
Wait. I’m going to need this dumbed down a little. Where is said coolant tank? How do you inspect it?
Beetlebug62
Beetlebug62
Ken
Maine, USA
Are you talking about the last image? The coolant loop? That's in the service menu. Access the service menu, go down to the snowflake in the menu and one of the options in the list shows the octovalve coolant loop.
If you mean the coolant tank, it's in the frunk. Take off the top trim piece and you can see the top of the washer tank, on left; the top of the brake fluid tank, on right; and the coolant tank in the middle. I realized I couldn't see any fluid thru the side of the tank, so I opened it and looked.
Tesla Roadster 2nd gen Coolant fluid top-off? IMG_0674
You can see droplets of fluid on the top of the bottle, but nothing shows on the sides. Open it, it's virtually empty.
Tesla Roadster 2nd gen Coolant fluid top-off? IMG_0676
I’ll have to look at mine when it gets back from its terrestrial armor spa day
JCERRN
Around
Yeah
Anyone know?
Hmm, youd think there would be a warning about low coolant. Theres one for the windshield fluid. Not sure if like a gas engine, most of the coolant stays in the system and the reservoir is more for overflow and filling? I wonder if theres a procedure to check coolant level
For sure. There is a procedure for taking a shit at Tesla. Wait patiently and @mongo or someone will post it here eventually. lol.
Ummm... I'm don't have a procedure #2 in my reference book.
However, as regards coolant, one can test thermal system performance, but I wouldn't recommend adding coolant since that could mask an internal pack or drive unit leak (though issue was more likely an air bubble that was finally burped).
https://service.tesla.com/docs/Cybe...UID-E9F45EDA-E487-4C78-8AEB-FA9FCE1D1B41.html
Tesla Roadster 2nd gen Coolant fluid top-off? AISelect_20251108_061049_Firefox
Beetlebug62
Beetlebug62
Ken
Maine, USA
I'm pretty sure there is a low coolant warning. The reservoir has the "Max" fill line, and then I assume the seam is the minimum line.
